[ANSYS Meshing] Cylinder non-uniform Mesh
Old   December 4, 2012, 22:17
Question Cylinder non-uniform Mesh
babak.mahjoub is on a distinguished road
Hi guys, at the moment I'm dealing with meshing for flow over a 2d circular cylinder. Actually in some tutorials I saw that the domain was defined as a circle as well, but I saw in some articles that a rectangular domain was used and the grids around the cylinder was well biased. (shown in the picture)
I want to do the same but I couldn't figure it how!
Is it s.th that should be considered in design modeler or is it a Mesh technique?
pls see the picture and tell me how to mesh like it
thx in advanced for your helps
babak.mahjoub is offline   Reply With Quote
Old   December 4, 2012, 23:55
Far
Sijal
I am not sure about the AM, but for making the map mesh you need Design modeller first.
But this process is very much simple in ICEM CFD, if you wanna try see this.
http://www.cfd-online.com/Forums/ans...cylinders.html
Old   December 5, 2012, 08:25
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Yes, if you want that kind of mesh using Ansys Meshing you first need to split the domain in for example Design Modeler. The splits are exactly the same shape as the blocks would be in ICEM
jrunsten is offline   Reply With Quote
circular cylinder, non-uniform mesh
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 07:32
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 02:31
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
