Volute
Hey everyone!
I've done several volute hex meshes in the last month. As I know, how annoying it could be to achieve a reasonable quality, I decided to provide my blocking approach and/or my scrip file to anyone, who's interested So if you become desperate on trying to make a good blocking, just let me know.....I'll help you out ;) |
please i have a problem with volute meshing, i need a help
volute meshing
i want generate a hex and tetra meshing withe a good quality
generate a hex and tetra mesh with a good quality
I have generated a hex mesh of the volute but I have in the area of cut water a problem and for tetra mesh I could not generate a good mesh.
I want to generate a hex grid and another tetra mesh with prism with good quality I want how i can generate a hex and tetra mesh with a good quality. please i need a help. thank |
1 Attachment(s)
CAn you share your tin file
volute meshing
thank you for helps it
how i can me with hex and tetra with good quality :confused::confused: |
take a look at the simon's tip and trick, it has a procedure on how to perform a blocking for a volute
volute meshing
thank you for your reply, i will read it
Best Regards |
I wait your help
i have problem to meshing the volute please i need your help
2 Attachment(s)
hi
I spent enough time to mesh the volute I used icem cfd (see the picture) but I have a problem of the negative element in the area of cut water. thank you Best Regards |
hello
I used to icem cfx14.5 realized this mesh but I have the message of negative Elements in cfx pre at the area of water cut my question is: how to avoid this problem (the complexity of the geometry) and how to avoid inverted blocks thank you my friends |
sometimes you can't really do something against the complexity of the geometry, you then have two choices:
Change it in a more simplified one. Or go with the unstructured mesh... it's your call |
hi
thank you my friend for the document, I will try to change the mesh; best regards |
