[ANSYS Meshing] Problem of Meshing a orifice within a very thin pipe
Old   December 8, 2012, 15:37
Question Problem of Meshing a orifice within a very thin pipe
Yiyuan YONG
justeyong is on a distinguished road
Hi there,
I'm simulating the flow in orifice meter. The diameter of the pipe is 12.5mm, and the orifice diameter is 4mm. The following figure shows the geometry of the orifice.
When I doing the mesh, I separated the body into serval small rectangular parts. However, one of the rectangular is very small. How do I mesh that one?
justeyong is offline   Reply With Quote
[snappyHexMesh] Meshing U-shaped cylindical pipe stainboy OpenFOAM Meshing & Mesh Conversion 0 November 11, 2012 21:01
Meshing problem Gambit-fluent ajay FLUENT 3 January 28, 2011 01:42
meshing at a pipe intersection cyn FLUENT 0 December 20, 2006 02:16
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
