Home > Forums > ANSYS Meshing & Geometry
[ICEM] Merge problem
Old   December 17, 2012, 12:52
Default Merge problem
Gerrald Gelderblom
DoubleG is on a distinguished road
When I try to merge an unstructured mesh and a structured mesh, for some reason it doesn't work. I included an attachment with an impression of the geometry. Does somebody know how to solve this?
The error it gives is (as visible in the attachment):
I am trying to include edge 81107 62911 but vertex 81107 isn't even in the region 1
unable to include quad 168283 (81100 62912 81107 62911)
I tried to play with the following things, but it didn't work:
Add or remove surfaces at the interface.
Change face association at the interface for the blocking.
I know that the mesh sizes don't match that well in this case, but that should not be a problem.
Has somebody an idea?
Thanks in advance,
Gerrald
DoubleG is offline   Reply With Quote
Old   December 17, 2012, 13:29
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
rules for merging tetra with hexa:
keep it simple... one surface which will be your interface.
Merged surface must share a perrmeter 100%
Both meshes must be projected to that perrmeter
About size: 0.7 (hexa) to 1 (tetra) is best
From Simon tip and tricks
I have some free time, we can investigate together the project if you don't mind sharing your project...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is online now   Reply With Quote
Old   December 18, 2012, 09:05
Gerrald Gelderblom
Thanks for the help, I now simplified the geometry using the create topology command, and it seems to work.
What do you mean by investigating together? I can send you the geometry, it is just a geometry from literature which I want to use for validation.
Gerrald
Old   December 18, 2012, 12:05
diamondx's Avatar
Ghazlani M. Ali
Let's take a look together, please use dropbox or somewhere i don't have to register
Regards,
Ali
Old   December 21, 2012, 10:18
Gerrald Gelderblom
That would be nice. I wanted to try by myself, also because I need to get used to ICEM, but I still don't manage to fix it. I always keep the troubles of geometry which seems not to be closed and those kind of errors.
In the hyperlink below you can find a .tin file of the geometry and a description of the geometry. I need three impellers who can rotate in a baffled vessel. For this reason I made a cylindrical interface around each of the impeller, and I want to apply a MRF approach to these interfaces. I also need to include free surface flow, so on top of the cylinder I made another volume which I could fill with air initially. Finally I also need a place to inject some tracer during a transient analysis in order to track the concentrations.
The article describing the geometry is (I use the bigger geometry from the file):
CFD simulations and experimental validation of homogenisation curves and mixing time in stirred Newtonian and pseudoplastic liquids from Montante et al. A screenshot of the geometry (T=48cm) is presented in the dropbox as well. The vessel is baffled with four flat baffles of width T/10.
Due to holidays I don't have access to Icem coming two weeks, but I can still correspond.
Thanks in advance,
Gerrald Gelderblom
Click here to view MONTANTE.
Thread Tools
Trackbacks are On
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 3 February 23, 2013 21:41
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
