[DesignModeler] How to avoid duplicate faces when Importing from GAMBIT to ANSYS 14
Old   December 17, 2012, 10:15
Default How to avoid duplicate faces when Importing from GAMBIT to ANSYS 14
yahya
yahya is on a distinguished road
I have read in the designmodeler user guide that "when importing from GAMBIT software into the ANSYS DesignModeler application, solid bodies in a multi-body part will be separate forming a manifold model (shared GAMBIT faces will be duplicated for each body)". I want to avoid this duolication of faces
can anyone help me in this problem?
Does the "share topology" work this out?
yahya is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine kbhamidipa3 FLUENT 0 November 30, 2012 15:52
define faces within GAMBIT in imported mesh Elmar FLUENT 0 February 25, 2001 07:10
