[ICEM] nodes in sweep direction not evenly distributed
Old   December 18, 2012, 12:49
Question nodes in sweep direction not evenly distributed
Felix Marlow
fmarlow is on a distinguished road
Hi Fellows,
in ICEM I have a swept block with a planar an a convex surface as free faces. On all side faces the nodes are distributed evenly in sweeping direction (according to the edge parameters of the side). But inside the volume, where the extension in sweeping direction is larger as on the side faces, all except one layer of elements have the same thickness as on the side faces and the last layer fills the rest. The attached picture should make clear what I mean.
I want to have an even distrubution of nodes in sweeping direction across the whole volume. Has anyone an idea what causes th problem?
fmarlow is offline   Reply With Quote
Old   December 19, 2012, 03:32
Lightbulb Solved!
Felix Marlow
All right, I got it. I just slept a night over it and now I found a way.
I just changed the block IJK. I guess this way the mesher started sweeping from the opposite face which obviously works better.
But another Question (would probably be better in another thread, but its not that important): Meshing the free faces with quad dominant results in more triangles (in 3D prisms) than meshing with all quad. Are there any preferences for the solver (CFX)? Like the less prism the more robust?
blocking, swept
[OpenFOAM] Evenly distributed arrows using glyph in ParaView kriz ParaView 4 January 26, 2016 03:23
[Other] How can count the nodes in radial, axial direction in turbogrid? Saima ANSYS Meshing & Geometry 0 May 2, 2011 11:40
help,the nodes' moveing direction in DM ellen peng FLUENT 0 March 25, 2009 02:50
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
