December 19, 2012, 08:00 |
How to trim this surface?
S.Bogoda
Dear All,
I don't know whether I am asking a very basic question. But Really appreciate your helps. I want to delete the intersection plane of two axial cylinders as shown in attachments. (image 1/2) I followed following steps; 1. Made surface-surface interaction by a Bspline in to two parts. (image 3) 2. Segment/Trim the curved surface by using created curve in step 1. But in this matter, the curved surface cannot trim and only damage the surface. (see in attachments: image 4) I have used this method to trim intersecting surfaces in many cases as cylinder-cylinder or cylinder-rectangular plane. Then why this happens only in this situation? |
December 19, 2012, 08:49 |
AB
Rep Power: 21 |
Redo the surfaces with the option "from 2 or 4 curves" and retrim.
that should work. |
December 21, 2012, 00:46 |
S.Bogoda
Dear All,
Thanks a lot for replies. I couldn't trim it with the option "from 2 or 4 curves", but worked with the option, "surface of revolution". I don't know why ICEM is not allow to trim a circular surface, but other shape of surfaces. Dear Far, I want to trim that one to make the flow path. Actually this is not the real geometry, is a trial. |
March 5, 2013, 05:41 |
SSL
Is it possible to trim a surface by surface in ICEM?
March 5, 2013, 06:18 |
S.Bogoda
Try with trim by "By connectivity" option (no experience with this). But I always do trim in two joint surfaces by making a curve on joint line. You can do this using "surface surface intersection".
March 5, 2013, 06:24 |
AB
Rep Power: 21 |
Build topology would do it I think.
March 5, 2013, 08:17 |
Not directly. First you have to create the curve at the intersection of two surfaces and then go to surface tool and segment surface by these curves you have just created.
Build topology is awesome tool, give it try and you will save alot time. But some times it is tricky to handle it. |
September 17, 2022, 10:24 |
problem in trimming
Rep Power: 7 |
I am unable to trim the NACA0002 surface from domain around it. Kindly let me know the issue and how could I solve it. All other NACA are working well just NACA0002 encountered the problem.
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
Comsol (4.3): convert parametric surface into block? | sgalaz | COMSOL | 0 | November 9, 2012 10:20 |
import solids | Alessio85 | STAR-CCM+ | 5 | November 11, 2011 14:16 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 07:47 |
