-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] regarding meshing an airfoil (http://www.cfd-online.com/Forums/ansys-meshing/110851-regarding-meshing-airfoil.html)
RAJ KIRAN December 22, 2012 15:25
1 Attachment(s)
hi every one
i'm trying to mesh an airfoil (which has a cylinder above its upper surface), i have done most of it ,but i'm not satisfied with the blocking stratgey i have used ..and i'm also not sure the way i used ogrid is correct..
and what actually happens when we create a ogrid by selecting external blocks and what happens when we create it using internal blocks?? if both are same which one i should prefer ???
i have attached here my project file
looking forward for a reply
Far December 22, 2012 16:11
1 Attachment(s)
What do you think about this ...
RAJ KIRAN December 22, 2012 19:00
thanks for the reply
i tried the way you used the blocking strategy but i couldnt get it .
after splitting the cylinder should i merge the vertices with the vertices which come from splitting the airfoil ?
RAJ KIRAN December 23, 2012 00:37
FAR hoping for your reply
RAJ KIRAN December 24, 2012 05:59
1 Attachment(s)
i tried using your blocking strategy, i got most of it ,but i cant get this linearity..
plz help me with this
Far December 24, 2012 06:15
you have merged the vertices, dont do it. Start with O-grid and make the splits as required. For example I made two o-grid splits for the cylinder.
Also you can choose the C-type blocking by collapsing the block at trailing edge.
RAJ KIRAN December 24, 2012 15:25
Thaks a lot
