-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [GAMBIT] Size function in gambit (http://www.cfd-online.com/Forums/ansys-meshing/110889-size-function-gambit.html)
crispysalt December 24, 2012 04:17
I have a large box with 2 smaller boxes inside of it. When I am applying size function to the volume to limit the number of cell in between the two smaller boxes, what should I choose for source and attachment? What does it means?
Thank you.
-mAx- January 3, 2013 02:39
are your both small boxes hollow?
crispysalt January 3, 2013 02:47
Yes, they are hollow.
-mAx- January 3, 2013 03:08
ok
display pictures and how many volume do you have?
crispysalt January 3, 2013 03:25
Dear mAx, can I have your email? i sent you the pictures through email.
Thank you
-mAx- January 3, 2013 03:46
In your case I would split the region of membrane-elements, and then you can deal with all your isolated elements separately. (only mesh them with hexa)
Advantage is that you won't have any problem by meshing only one volume, but with several small entities (with size function) --> it will ask lots of ram memory from gambit, and it will fail
crispysalt January 3, 2013 04:02
Thank you!
crispysalt January 3, 2013 05:02
When i try meshing using hex and cooper, gambit gave me an error message saying that volume contain a void and thus cannot be meshed using the cooper scheme. What can i do?
-mAx- January 3, 2013 05:11
if your splits are correct, then the volumes resulting should be automatically set as cooper (or hexa).
to see how your volume looks like, go in visibility (specify display attributes), and select only your volume
