[GAMBIT] Size function in gambit
Old   December 24, 2012, 03:17
Default Size function in gambit
crispysalt is on a distinguished road
I have a large box with 2 smaller boxes inside of it. When I am applying size function to the volume to limit the number of cell in between the two smaller boxes, what should I choose for source and attachment? What does it means?
Thank you.
crispysalt is offline   Reply With Quote
Old   January 3, 2013, 01:39
-mAx-'s Avatar
Maxime Perelli
are your both small boxes hollow?
Old   January 3, 2013, 01:47
Yes, they are hollow.
Old   January 3, 2013, 02:08
-mAx-'s Avatar
Maxime Perelli
ok
display pictures and how many volume do you have?
Old   January 3, 2013, 02:25
Dear mAx, can I have your email? i sent you the pictures through email.
Thank you
Old   January 3, 2013, 02:46
-mAx-'s Avatar
Maxime Perelli
In your case I would split the region of membrane-elements, and then you can deal with all your isolated elements separately. (only mesh them with hexa)
Advantage is that you won't have any problem by meshing only one volume, but with several small entities (with size function) --> it will ask lots of ram memory from gambit, and it will fail
Old   January 3, 2013, 03:02
Thank you!
Old   January 3, 2013, 04:02
When i try meshing using hex and cooper, gambit gave me an error message saying that volume contain a void and thus cannot be meshed using the cooper scheme. What can i do?
Old   January 3, 2013, 04:11
-mAx-'s Avatar
Maxime Perelli
if your splits are correct, then the volumes resulting should be automatically set as cooper (or hexa).
to see how your volume looks like, go in visibility (specify display attributes), and select only your volume
Size function problem Joren ANSYS Meshing & Geometry 2 April 9, 2010 07:06
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
