[DesignModeler] having problems with filling geometry |
January 8, 2013, 14:23 |
#22 |
Michal
Rep Power: 13 |
Could you fill last time geometry for me because meshing process is too complicated and I have decided to make geometry more simpler.
Link: http://fs05n1.sendspace.com/dl/fd26f...-engine-3.agdb |
August 7, 2013, 06:37 |
#24 |
Michal
Rep Power: 13 |
Some times ago you did sth for me could you next time fill attached geometry as mentioned above?
http://www.sendspace.com/file/sbsz0d Thank you, regards, Michal Last edited by magnusDux85; August 7, 2013 at 09:06. |
August 7, 2013, 12:10 |
#26 |
Michal
Rep Power: 13 |
I have done it by myself it was easy .
August 7, 2013, 12:12 |
#28 |
Michal
Rep Power: 13 |
There is one thing to do in this chamber: swirling flow in fuel inlet modeling, have you ever did sth like that?
August 7, 2013, 16:34 |
#30 |
Michal
Rep Power: 13 |
I modeled the injector as a point source of fuel and based on this I am planning to mimic swirling flow..
August 9, 2013, 00:07 |
#31 |
Ghazlani M. Ali
Rep Power: 28 |
i am actually working on something similar. but i have a simplex nozzle. the air flows around the tip to create a swirl. that's what I am meshing right now. you need a geometry for your injector. then I model the injection using dpm
August 9, 2013, 02:46 |
#32 |
Michal
Rep Power: 13 |
My geometry is here: http://postimg.org/image/hj4w0kz45/
August 11, 2013, 16:23 |
#33 |
Michal
Rep Power: 13 |
Could you show your nozzle geometry?
August 11, 2013, 16:40 |
#35 |
Michal
Rep Power: 13 |
Ok understood.
So maybe you can give me a tips about my case? |
August 11, 2013, 16:50 |
#37 |
Michal
Rep Power: 13 |
Swirling flow making by means of nozzle modeling is still problem for me. It is difficult to find exact geometry/scheme.
July 29, 2015, 04:46 |
#38 |
Shaheer
Rep Power: 10 |
Hello I am doing a simulation of a combustion reactor I compiled the geometry file and now i need to mesh the inner cavity rather than the wall i imported. How do i mesh the inner cavity? Do i use fill on it? I tried to do some basic filling but i am getting error message. Help on this matter will be appreciated.
Display Modes | |
[DesignModeler] Fill tool - grouping the faces of a complicated geometry? | HeikkiT | ANSYS Meshing & Geometry | 8 | July 20, 2016 07:37 |
Having problems creating a hole in a geometry of a meshed case | zaidhadi | FLOW-3D | 3 | April 4, 2016 16:49 |
[ICEM] Geometry accuracy problems | crook108 | ANSYS Meshing & Geometry | 0 | November 26, 2012 06:48 |
help plz! problems in filling times : new user | shankar | FLUENT | 0 | July 24, 2003 12:58 |
Adaptive optimization of geometry | Jan Rusås | CFX | 1 | September 16, 2000 02:38 |
