[ANSYS Meshing] Boolean creation error - operation would result in non-manifold bodies
Like Tree3Likes
Old   January 10, 2013, 03:34
Smile Boolean creation error - operation would result in non-manifold bodies
Akshay
thefinalyearkid is on a distinguished road
Hello! So im currently working on a project that requires me to analyze the flow around a vehicle in this case - a renault clio
So i obtained this model and saved it as a parasoild and then imported it into ANSYS, then, i generated a enclosure to depict air as usual and went about creating a boolean to substract the vehicle from the air(enclosure)
This is where the error of 'non-manifold' bodies occurs, i have read some other posts on some inability to substract surfaces and im not too sure on how to go about resolving this issure!
Please help!
thefinalyearkid is offline   Reply With Quote
Old   January 10, 2013, 04:53
Sixkillers is on a distinguished road
Before subtract operation I would definitely unite the hole car into a one body.
Sixkillers is offline   Reply With Quote
Old   January 10, 2013, 10:35
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Yes the problem is the surface/solid operation.
Designmodeler cannot perform an operation between solid and surface.
when you import the car, you have to fill the inside with a some solid. There is a feature called FILL in designmodeler that let's you do that.
After the fill is done, delete those surfaces as you don't need them, you can do that with body operation then delete.
Then make that rectangle and perform the Boolean feature.
A more easy way is to import your car as a solid and not as a surface, i guess this is done when exporting you car in the CAD software in which you made the car ? try an extension like IGES , or STEP...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 10, 2013, 10:50
diamondx's Avatar
Ghazlani M. Ali
also see this http://www.cfd-online.com/Forums/ans...29-bug-dm.html
Regards,
Ali
Old   January 10, 2013, 20:58
Smile
Akshay
Ah yes! Brilliant, so the open surfaces is what causes the problem in DM,
anyhow guys i was doing some research and found this software called blender, and the link shows some amazing features that actually tell you the location of non-manifold body errors and allows for you to very simply cover up the open surfaces
the youtube link is :
http://www.youtube.com/watch?v=H6NXhfw9itI
and the website link is :
http://www.blender.org/download/get-blender/
Old   May 16, 2013, 15:38
Thumbs up my solution
Pjotr
oewnce932c is on a distinguished road
Hi thefinalyearkid.
i got the same problem. i imported ship hull from IGES(500+ surfaces), just half hull without deck. i wanted to creat a body from it. Done 2 surfaces: deck and mid-ship.
after that tryed with Body Operation: Sew this three objects: 2 created surfaces and surface-body(IGES(500+ surfaces))
with default tolerance was warning and errors:
"Warning: Sewing operation partial failure possibly due to incompatible attributes"
"Warning: not all bodies can be sewn or converted to solid body"
and by boolean: subtract
"Error: Operation would result in non-manifold bodies"
solution was to reduce the tolerance from default value(0.0015m) to 0.015m. after that it works fine!
yachting_rus cup
world amateur racing tour
WWW.YRC.DK
oewnce932c is offline   Reply With Quote
Old   April 24, 2014, 11:42
Default non-manifold
saeed
saeed.marine is on a distinguished road
hi.
i have an IGES file of a container ship (KCS-hull). but it is just the surface of it. how can i turn it into an solid body? in order to perform a Boolean operation on it.
saeed.marine is offline   Reply With Quote
Old   April 24, 2014, 11:55
Pjotr
load your ANSYS file. for example with this http://dropmefiles.com/en
your use DesignModeller?
yachting_rus cup
WWW.YRC.DK
Old   April 24, 2014, 12:02
saeed
it is already on the net.
http://www.simman2008.dk/KCS/kcs_geometry.htm
KSC hull
yes i use DM
Old   April 24, 2014, 12:42
Pjotr
here it is.
i took this file for ship hull http://www.simman2008.dk/PDF/KCS_hull_SVA.zip
couple of steps -> see screenshot
here is DM file for your with SOLID http://pjotr.ru/data/kcs_cfd_online.agdb
ps do your know any results or cases for KCS with self propulsion tests?!
yachting_rus cup
WWW.YRC.DK
Old   April 24, 2014, 12:59
saeed
i haven't worked on it myself. but surely some friends of mine know. they have done several test on it (in towing tank).
i believe you are using a later version of DM. i cannot open it!
mine is 14.0
Old   April 24, 2014, 13:08
saeed
can you give me an .stp file please?
Old   April 25, 2014, 05:40
Pjotr
oh.. yes my is 15.0. do your know how to save for "older" version?
here are steps, tree in DM is in attach
0. delete two surface in the bow, above main deck
1. create line and surface in prop shaft
2. create mid line of the ship z=main deck
3. create deck surface
4. create surface at y=0, have to select many lines
5. sew ship. Solid=yes. Change Tolerance to 0,1 or less if no solid is created.
here is stp-file http://pjotr.ru/data/kcs4cfd_online.stp
yachting_rus cup
WWW.YRC.DK
Old   April 27, 2014, 05:24
saeed
thank you. it was a great help to me.
what do you want to know about KCS hulls?
Old   June 19, 2014, 12:18
AZ
mjthomp3 is on a distinguished road
Please help!
There is a very useful tutorial from ANSYS website in design modeler that
goes through all these steps but for a Sedan. I found it very usefulas you
might as well.
The basic steps go like this:
1. connect all the edges
2. Tools > merge
3. Tools > Surface patch to fill gaps in surface body
4. Use sew to convert the surface body to a solid body
with Body Operation
and lastly
5. Enclosure with 1 surface plane
mjthomp3 is offline   Reply With Quote
Old   August 16, 2017, 02:30
Default SAME PROBLEM... 'non-manifold' bodies occurs
  #16
PENANG
musa19 is on a distinguished road
Hi, I am trying to analyse FSI over wing. I obtained a wing model in Solidworks by part design, importing NACA geometry and developing ribs, etc and then extruding a surface to cover them. But, after importing the geometry to ansys workbench, i have obtained two geometries, as inside solid part and surface. I am not able to obtain successful Boolean due to two different geometries. KINDLY CHECK ATTACHED IMAGE.
Any help will be highly appreciated.
musa19 is offline   Reply With Quote
Old   August 16, 2017, 20:21
Kapi is on a distinguished road
one is surface body and other is solid body.
suggest you to search forum for similar questions, you will get answer and much more details about your model.
Kapi is offline   Reply With Quote
Old   February 18, 2018, 17:56
Eduardo Fernandes
ecortereal is on a distinguished road
You did it? Can you explain how you did this? I have the same problem!
ecortereal is offline   Reply With Quote
Old   March 12, 2018, 15:12
Sri Harsha Maddila
harsha2398 is on a distinguished road
A non-manifold error is showing up whenever I try and use 2 symmetry planes to generate an enclosure around my car saying it cannot because of non-manifold bodies. I don't understand what I should do to resolve it, can someone tell me what it is I should do?
Here's the geometry of the file and relevant screenshots:
https://1drv.ms/u/s!As6k8_h0tQpljp0yxFAy57fcW3RxwA
I use the STEP file for Ansys Workbench 18.2. Please suggest what it is that I should do!
My symetry planes are ZX plane and YX plane, but it throws up the error when I mention the ZX plane! And are there any other errors in the geometry that can affect the simulations later?
harsha2398 is offline   Reply With Quote
Old   July 3, 2018, 19:59
Hassan Alahdal
Hassan99 is on a distinguished road
how can you unite it into one body?
Hassan99 is offline   Reply With Quote
boolean, meshing, non-mainfold
Info message -> Fluent does not start Jenson FLUENT 0 December 22, 2011 18:21
creation of 3d bodies within an assembly Roland CFX 1 August 8, 2006 12:49
