-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [TGrid] tet gemeration not working (http://www.cfd-online.com/Forums/ansys-meshing/111963-tet-gemeration-not-working.html)
diamondx January 18, 2013 14:53
Dear cfd-onliners,
i've got this boundary mesh very simple, a cube in Tgrid.
https://dl.dropbox.com/u/35161486/tgrid.png
The tet generation just doesn't work. error is "duplicate nodes", why is this happening, how can i solve it ??
Thanks a lot
The mesh file is here:
https://dl.dropbox.com/u/35161486/test.msh
Far January 18, 2013 16:03
Ali there are two solution.
1. Get good mesh for Tgrid from ICEM OR
2. Repair manually the problematic nodes.
diamondx January 18, 2013 16:07
i don't see what is wrong with this mesh. In icem, i generated shell mesh using delaunay for each surface individually. there is a distorsion in the size of the elements because i forced it to match a curve bunching law...
diamondx January 18, 2013 16:13
Also in icem sometime when generating the delaunay after the octree it gaves me an error:
Application did not finish correctly.
Error: tri2tet exited with a non-zero status
Any idea ?
diamondx January 18, 2013 16:57
i think the problem comes from the curves's node distribution... just check with a normal cube and it works
