[ANSYS Meshing] Partially swept mesh
Old   January 25, 2013, 15:19
Question Partially swept mesh
Taylor
tfarnham is on a distinguished road
Hi all,
I'm new to FLUENT and am attempting to use sweep controls for a select portion of the my model. Flow enters in the center disk, proceeds outwards through a number of channels, and then exits a pressure outlet (setup visible here: http://i.imgur.com/FH9BMCd.png )
I am looking to create a swept mesh along the length of the channels, while maintaining resolution around the channel entrance and exit. I have had partial success by breaking the entire model into three sections (inner, channel, and outer) and using Mesh Methods for the swept channel.
Ultimately I'm looking to your expertise on more efficient ways of doing this. I've tried applying a Swept Mesh condition to the entire geometry, and it failed to mesh.
Thanks in advance,
Taylor
tfarnham is offline   Reply With Quote
channel, mesh, partial, sweep, swept
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
