Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] Need some help with DesignModeler
Old   January 21, 2013, 14:43
Default Need some help with DesignModeler
S1m0n1 is on a distinguished road
Hi, I am trying to model a 3-D room with various inlets and outlets. In the end, I would like to be able to see the pathlines of the flow, along with the flow of different types and sizes of particles I inject. Right now I am having trouble completing the 3-D geometry with the inlets/outlets.
So far, I have done the easy part in completing the solid rectangle. Now to add the inlets/outlets is where I'm stuck. All I did was draw a rectangle on 2 different surfaces and I created a surface from the sketch. Is this how I would go about doing this? When I tried to mesh it I couldn't get the mesh to work. I want to have at least one inlet/outlet on each wall and the ceiling.
All help is greatly appreciated. Thanks in advanced!
S1m0n1 is offline   Reply With Quote
Old   January 22, 2013, 03:36
zhao xin
zxin is on a distinguished road
There is an operation in Extrude called 'Imprint Faces'
zxin is offline   Reply With Quote
Old   January 22, 2013, 19:18
Thanks for the reply, it helped out a lot.
Ok, so I have impinted all of the inlets and outlets that I would like to use. I just want to run this by anyone looking at this to see if what I did make sense and will work.
So here is what I have so far: Sorry, for some reason it wouldn't let me insert the picture.
I imprinted all of the inlets/outlets and selected "To Next" for Extent Type. I think this extended them into the body. By doing this, does this only cause the rectangles to be on the surface, acting like actual inlet/outlet vents? If not, how can I do this?
Last edited by S1m0n1; January 22, 2013 at 19:20. Reason: Give thanks to person who replied
Old   January 23, 2013, 03:47
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Imprint only affects the surface, so you're good.
jrunsten is offline   Reply With Quote
Thread Tools
Trackbacks are On
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 47 September 7, 2016 22:52
[DesignModeler] find features of Gambit in DesignModeler code_source ANSYS Meshing & Geometry 13 April 30, 2014 07:33
Physical size of geometry in DesignModeler Michael Rasmussen CFX 7 August 29, 2012 16:59
[Other] exchange of parameter values between TurboGrid and DesignModeler in Workbench la7low ANSYS Meshing & Geometry 2 February 21, 2011 16:12
How to create a variable-pitch helical sweep in Designmodeler (v11.0) dgasperi ANSYS Meshing & Geometry 0 August 13, 2009 13:11
