-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Room with table meshing (http://www.cfd-online.com/Forums/ansys-meshing/112104-room-table-meshing.html)
asal January 22, 2013 08:06
Hello everyone!
I have a geometry with a table at the center of the room.
I want to provide a mesh for this geometry. First I create a block for the hole room, and them a block for the table. But I don't know how can I subtract these two blocks. now ICEM made a mesh for table and for room separably, but I want to consider it as a unite volume.
take a look on the figures.
is there anyone here who can help me?
thanks
http://i50.tinypic.com/30dh2ix.jpghttp://i50.tinypic.com/x51bf7.jpg
Far January 22, 2013 09:18
No need to apply boolen operation in ICEM.
What is the problem with mesh? Did you make the surface mesh only?
asal January 22, 2013 11:14
Yes, this the surface mesh.
But usually we create a block for hole the geometry, then cut it out to delete the part which we don't want to have mesh.
But I create two separate block one for room, and one for table, now I want to know how can I create the mesh for the room, just like when we create the geometry for the whole room and cut out the table from the room.
Let me to give you a simple Example:
http://i48.tinypic.com/29w4bab.jpg
I want to know how can I eliminate a part of mesh in my geometry without cutting out the main block
for instance I have two Cubic box (above picture). one inside the other. then I create a block for the big one, and another for the small one. when the ICEM ask to merge or replace, I merge them. usually we should cut out the big box block to have a block for the small box and delete this small blocks which is creating by this cutting out process. But by doing this your main block must be cutting to several slice in order to be able to eliminate the small block inside the main block. but I don't want to that.
So now I want to provide the mesh between the surface of inner and outer cubic boxes and not cut the big one. Is it possible to do this?I don't want to have a mesh inside the inner box.
thanks.
diamondx January 22, 2013 13:24
from what i learned here, that is the top down approach, and this is how icem works. if you wanna start by the small cube, you can expand it by extruding, but this method is not efficient...
Far January 22, 2013 16:32
thanks.
Your approach is wrong. Please try some tutorials
