-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Tetra boundary layer (http://www.cfd-online.com/Forums/ansys-meshing/112205-tetra-boundary-layer.html)
mario1701 January 23, 2013 16:52
I have to create a tetra boundary layer around a high-speed train in ICEM and I wondering what is the best way to do it - so far, I have read just about hybrid meshes or prism boundary layers (as I have mentioned before - it has to be tetra mesh). I would be very grateful for any smart methods.
Mario
Far January 23, 2013 17:24
1. tetra size ratio
2. tetra width
http://imageshack.us/a/img267/8161/51943058.jpg
diamondx January 23, 2013 19:39
sorry for jumping in, i have a question in the surface mesh tab, what does tetra width useful for ???
diamondx January 23, 2013 19:51
i have chaging it but nothing change ??
Far January 23, 2013 23:42
It is working when you define the tet width and ratio for the volume meshing. It applies these settings on volume and surface. But only for surface meshing, I dont think they have any effect.
PSYMN January 24, 2013 09:12
Tetra width specifies the number of elements into the volume before the tetra ratio starts to expand the mesh. It only works with Octree Tetra.
If I had a surface size of 2 and a max size of 64 and a tetra width of 3, I would get at least 3 layers of size 2 volume mesh before the mesh started to expand up to the max size.
It is like putting a mesh density region near the surface, and in fact, works the same way in the back ground.
mario1701 January 26, 2013 11:04
Thank you very much for reply, but in case of using wall functions, it doesn't influence the results (y+ is not decreasing). I thought rather about characteristic "elongated" shape, which can be obtained with use of the prism mesh. Maybe I should create such a prism mesh and then convert it into a tetra mesh?
Far January 26, 2013 11:09
Are you using scalable wall functions? What is the minimum wall Yplus in your simulations?
I think prisms are better than tetras
mario1701 January 26, 2013 18:11
I was using standard wall functions. Unfortunately, I have to use tetras (I use some special applications developed at my university that need tetra meshes). Y+ is still huge - on mesh of 126k nodes I have minimal y+ on the surface of locomotive equal approximately 2e3.
Far January 27, 2013 02:23
are you sure about units of your model?
Another option is to use the T-Rex type algorithm!!!
mario1701 January 27, 2013 13:04
When it comes to the units - everything seems to be correct. The mesh was created in [mm] and is correctly read by fluent (the main dimensions are presented in meters, but are for sure correct). I tried to create a prism boundary layer and then converted it to tetra - y+ decreased signifficantly, but the quality of the worst element is quite low (I am not sure if 0.05 - 0.1 for 15% of elements is a reasonable level - but maybe for boundary layer it does not matter (large pressure changes just in normal direction)?). ICEM does not support T-Rex, does it?
PSYMN February 6, 2013 10:54
Sure, use prisms to get the Y+ you want and then use the Edit mesh option to change mesh type and covert all to Tetra...
Roberto Meloni September 12, 2014 09:56
Transition between finer and coarse mesh zones
1 Attachment(s)
Hi All.
I have a problem with a mesh Iím trying to build and I wonder if you can help me to solve it.
My problem is that I canít define a proper transition between finer zones of the model and the coarse ones. I set up specific part size for the surfaces as well as for tetra size ratio, but it seems not to work fine. I believe that the system doesnít respect the mesh size of the mesh I specify on the surface, but it builds a very finer mesh.
Iíam meshing with the following setting:
- Robust(Octree);
- Patch Independent
- In the Global Mesh Size panel, I enable the Curve/proximity based refinement
The high density zones you can see from the picture refer to small holes. I have to mesh them with a very fine mesh (0.17 mm). The red zone refer to the core region of the model.
Could you please help me?
Best regards,
Roberto.
