[ICEM] What is the reason for this negative determinant? |
January 25, 2013, 11:05 |
Ye Zhang
Hello,guys.
Now I want to simulate the flow over wind turbine rotor, but when I am doing the mesh, there is a problem that says negative determinant when I check the mesh. you can see the bad cells(green) in the picture. so I want to know what is the reason for negative determinant and how to improve the bad cells? Thank you in advance. Regards Ye |
January 25, 2013, 12:28 |
Ye Zhang
Hi, M.Ali
Thank you for your reply. I can track(see)the bad cell, what I don't know is how to improve it? The green cells that have negative determinant looks quite triangle, right? but after the sharp trailing edge, I have get two blocks, is this the right method to deal with sharp edge? regards, Ye |
April 18, 2013, 09:59 |
kiddmax have you found a way to sort this?
I'm having the exact same problem with a sharp edge. The geometry and even the histogram look frighteningly similar too,, Let me know. Best, |
April 18, 2013, 10:13 |
Ye Zhang
Hi, Catthan
What about your blade? is it 3D or 2D? I advice you to use C grid for the sharp trailing edge. This is a tutorial on youtube. http://www.youtube.com/watch?v=mgjRT4WY_iA and make sure to use a block for "boundary layer", that will be much better. just like this |
April 18, 2013, 10:15 |
Ye Zhang
this is the picture
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
