Home > Forums > ANSYS Meshing & Geometry
[ICEM] Unreferenced faces
Old   January 25, 2013, 15:33
Default Unreferenced faces
Juancho Perez
juanchope is on a distinguished road
I'm new in the CFD world, i'm trying to replicate a case ran by ANSYS FLUENT people on the 4th Drag Prediction Workshop, organized by AIAA.
The meshes are available on their website (as .CGNS, .tin, .blk), the think is, i import it to ICEM in order to create the MESH file to be imported to FLUENT.
Once I try to read the mesh file in FLUENT, several problems appears:
- Invalid cell type 3. Skipping.
- Removing [number] unreferenced facez, zone [number].
- Warning: Number of nodes read (3592043) does not match number referenced (0).
- Warning: non-positive volumes exist.
- Skipping zone [name] (nor referenced by grid).
So, it is clearly a "reference" problem! the question is, how can I fix it?
Thanks a lot!
juanchope is offline   Reply With Quote
Old   June 25, 2015, 06:46
gautham narayan
gauthamnarayan is on a distinguished road
Hi juancho
I am currently facing the exact same problem in one of my meshes. If you you have solved the problem,kindly share the the solution.
gauthamnarayan is offline   Reply With Quote
Thread Tools
Trackbacks are On
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Native Meshers: snappyHexMesh and Others 8 September 13, 2012 09:28
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 1 June 7, 2012 13:39
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
