Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Blade tip blocking
Like Tree6Likes
Old   March 26, 2013, 07:57
Francisco
Bollonga is on a distinguished road
Originally Posted by Far View Post
can you make mesh under 1 million size? That is better starting point to set important parameters.
Well, I got a 5R radial, 5R upwind and 15R downwind domain around the blade with radious R. And I got to maintain y+<1.
Where should I reduce mesh density?
Bollonga is offline   Reply With Quote
Old   March 26, 2013, 08:02
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
How many nodes are on wind turbine? maximum 70-100 nodes may be enough.
reduce mesh in upstream and downstream blocks. First try mesh with Y+ > 30
Far is offline   Reply With Quote
Old   March 26, 2013, 08:06
Francisco
70-100 on the entire turbine surface?? R is 29 m, so it looks few nodes to me.
Old   March 26, 2013, 08:29
Francisco
Don't you mean 70-100,000 nodes?
Old   March 26, 2013, 08:31
Far
Sijal
I meant 70-100 nodes along blade length. Maximum 10-12 nodes in boundary layer.
Old   March 26, 2013, 08:33
Francisco
Ok. 10-12 nodes normal to the blade or in the airfoil section perimeter?
Old   March 26, 2013, 08:35
Far
Sijal
Normal to blade.
Old   March 26, 2013, 08:49
Francisco
So 70-100 nodes around the airfoil perimeter, 10-12 normal.
Considering chord is about 1m, and inlet is 145m away, which max size can I use for the inlet? The same for outlet which is 435m away.
Thanks!
Old   November 6, 2013, 14:59
gaurav kumar yadav
gaurav11 is on a distinguished road
Hi, I am working on propeller blade. I am very new to ICEM, and I am trying to block meshing, would anybody please suggest some strategy for my problem.
gaurav11 is offline   Reply With Quote
blade tip, hexa mesh, sharp edge, wind turbine
Thread Tools
Trackbacks are On
Meshing very thin blade tip Jenny CFX 7 June 27, 2014 08:26
Blade tip with tetra/prism method vinc ANSYS Meshing & Geometry 0 May 17, 2011 15:22
[ICEM] Blocking of impeller single blade sector (MRF) delaneyluke ANSYS Meshing & Geometry 1 May 6, 2011 09:28
[ICEM] Blocking strategy for 1mm tip clearance mr_stoked ANSYS Meshing & Geometry 2 September 21, 2010 15:00
[ICEM] Turbine blade with filleting and tip clearance Pursuor ANSYS Meshing & Geometry 4 July 7, 2010 13:56
