[ANSYS Meshing] Bubble modelling to simulate shape oscillations
Like Tree1Likes
  • 1 Post By -mAx-
Old   January 30, 2013, 12:16
Default Bubble modelling to simulate shape oscillations
Akash
akash is on a distinguished road
I'm trying to simulate a single bubble shape oscillation and I needed help in modelling it.
I created the grid using Gambit. The problem I'm facing is that the bubble interface is not being exported.
I have a made a square domain. At the center of the domain I've created a edge who's shape is that of the bubble. I meshed the whole square domain and then tried to split the mesh along the bubble interface. I'm getting some errors saying that the split is unsuccessful.
When I tried by creating two faces but meshed only the square domain, the bubble interface doesn't get exported because the other face is not meshed. I do not want to define two separate faces which are non-intersecting and mesh them, as that will not result in a structured mesh.
What I need is that the whole domain must be meshed as shown in the attached figure http://imgur.com/0lFY5jD. Then split the mesh along the bubble boundary so that it allows me to specify two different zones.
I'm fine if the grid is generated in any other software (Hypermesh or Pointwise or ICEM). At the end of the day, I just need Fluent to identify the two zones explicitly alongwith the bubble interface. Also note that the initial shape of the bubble is complex (not a conic).
Since the problem is 2D I'm attaching the .dwg and .tin files
http://www.sharecad.org/CADView.aspx...3-7d0c1b40c205
http://sdrv.ms/WfwFB0
Please Help!
akash is offline   Reply With Quote
Old   January 31, 2013, 01:25
-mAx-'s Avatar
Maxime Perelli
For the 2d-picture, in Gambit before you mesh both domains, you need to split the square with circle. Is gives you 2 connected domains: the disk and the square with an hollow.
Now if you want to work with interfaces, you need to disconnect both surfaces.
The quickest way (my point of view) is to copy the disk anywhere, then delete the disk at its original place. Now define both interfaces, and move the disk (copy) at its original place.
Both surfaces are disconnected, and you can mesh
Old   January 31, 2013, 09:07
Akash
The problem with splitting the square domain along the curve is, I'll not be able to get a structured grid. I needed a structured grid (all the cells must be rectangles).
Old   January 31, 2013, 09:38
-mAx-'s Avatar
Maxime Perelli
everything is possible
Here is on of many ways to get full hexa mesh
It is not nice, but I did it very quick
Old   January 31, 2013, 12:16
Akash
That's a good idea! But I also needed to grid within the circular region, to simulate air.
Old   February 1, 2013, 01:32
-mAx-'s Avatar
Maxime Perelli
akash likes this.
bubble, gambit, icem 2d, multiphase modelling
Bubble Column Modelling dlaw FLUENT 24 October 31, 2017 06:01
two phase modelling in bubble column srikkanth FLUENT 1 March 27, 2017 09:21
Modelling a bubble flow ina microchannel Aritra Sur FLUENT 0 April 25, 2008 11:19
modelling slug flow with pressure inlet Azman FLUENT 0 May 29, 2006 06:45
Modelling of bubble merging submerge on water Carlos Main CFD Forum 0 October 26, 2005 09:30
