[ICEM] GUI Style - change mouse colour?
Old   January 30, 2013, 15:40
Default GUI Style - change mouse colour?
Wallace Green
wallace is on a distinguished road
I'm using ICEM 14.5 on Windows 7. Under > Settings > Product > GUI Style, I prefer to use the black ICEM CFD background rather than the light blue Workbench background. However for both backgrounds the mouse stays the same colour, which is white for the normal pointer (not a problem) but black for the crosshair selection mode - this is obviously not visible on the black background. Can I set this to white as well somewhere?
wallace is offline   Reply With Quote
Old   January 30, 2013, 22:26
mjgraf is on a distinguished road
Just tested here and with Background color set to solid Black the Selection cursor changes to White. This selection was for selecting geometry for a part. Exactly which selection are you experiencing the black cursor on black background?
mjgraf is offline   Reply With Quote
Old   January 31, 2013, 03:17
Wallace Green
Yes, for example selecting geometry for a part. The cursor changes from the normal white arrow type cursor to a black cross - and it's black no matter what background colour I put, including black as well!
That's very odd that it's behaving differently for you. Are you also using v 14.5 on Windows 7 64 bit? I wonder is it related to the fact that I'm running the OS in Virtualbox. In any case you don't know any way of manually changing the colour of the cursor?
Old   January 31, 2013, 06:02
Wallace Green
This seems to be a known problem with "Mouse Integration" in Virtualbox. It can be worked around by switching to the black mouse scheme in Windows which makes all cursors black with a white perimeter - I find this ok.
Sorry that this is in the wrong forum - I'm happy for the administrator to remove the thread.
Old   January 31, 2013, 09:17
I was just about to ask if everything was installed properly for the VirtualBox integration. I was thinking it may be a OpenGL issue but if you found it to be a known issue, that works too.
The key for this issue was the VirtualBox which was not mentioned in your first post.
14.5, gui style, windows 7
How to change the font of FLUENT GUI for Linux Edition ? D10086 FLUENT 0 May 27, 2010 06:39
Important proposed change for Fluent/CFX GUI Cloigh CFX 10 April 30, 2006 03:01
Important change for Fluent GUI Cloigh FLUENT 8 April 26, 2006 06:29
GUI window settings cmv Siemens 0 February 7, 2005 06:22
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
