Home > Forums > ANSYS Meshing & Geometry
[ICEM] Meshing Problem, overlap.
Old   January 30, 2013, 20:51
Default Meshing Problem, overlap.
Jonathan Martin
vdrx84 is on a distinguished road
I am using ICEM CFD for a project I have acquired from a previous student and have been given a mesh that is representative of a blade inside a cascade. In the link below you can see how the mesh unfortunately fails. At the right hand side of the trailing edge the mesh overlaps itself. Also, to some extent the quality on the left hand side is rather poor. I am new to using ICEM CFD and I'm failing to understand where the mesh is going wrong. Any help or thoughts on possible issues with the mesh would be really welcome, thanks.
http://imageshack.us/f/706/screenshot1af.png/
Error messages:
bad params in create_edge_pars
and
error meshing edge (long list of edges here)
vdrx84 is offline   Reply With Quote
Old   January 30, 2013, 21:45
Jonathan Martin
It seems that if i perform mesh refinement on that specific block then the overlapping disappears. I guess that suggests that the volume it is trying to mesh on is too narrow and it cannot do it so it just crashes and overlaps the mesh, is that a correct assumption?
Old   January 30, 2013, 22:40
Far
Far's Avatar
Sijal Ahmed Memon (turboenginner@gmail.com)
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
I cannot see any overlapping in attached pic...
Best Regards
Far
http://cfd-consultancy.webs.com/
Far is offline   Reply With Quote
Old   January 31, 2013, 01:32
jeevan kumar
jeevankumarb is on a distinguished road
It seems like just cure association issue. try to correct the curve association for the blade.
jeevankumarb is offline   Reply With Quote
Old   February 3, 2013, 19:03
Jonathan Martin
sorry for the late response, been rather busy these last few days. Thanks for the replies though. I have been looking through the replay script and haven't found the problem yet. I am creating another script from scratch and will be modifying the blade slightly so the error should come up in this process.
The script for creation of the curves for the blade is a bit of a mess I have to say, which is pretty annoying, but I can't complain too much as it has saved me a lot of work.
endwall, icem cfd, pew
Thread Tools
Trackbacks are On
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 6 February 28, 2013 16:32
[ICEM] Hexa meshing blocking problem fergal ANSYS Meshing & Geometry 0 June 28, 2011 10:01
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 20:03
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 0 March 18, 2011 21:24
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
