[ICEM] Bluff Body Hybrid Mesh Icem
Old   March 5, 2013, 10:39
Default Bluff Body Hybrid Mesh Icem
Luca
LM4112 is on a distinguished road
Hello everybody
I need to replicate for my thesis an hybrid mesh of a bluff body using ICEM 13. I attached some pictures of the original mesh. What is the best way?
thanks in advance
LM4112 is offline   Reply With Quote
Old   March 5, 2013, 10:57
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
the person before you created a box around your bluff body. he blocked the geometry. then he generated an unstructured mesh for the outside box. and merged them together. look in the forum for merging structured and unstructured mesh.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 5, 2013, 12:47
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Ahmed body?
Far is offline   Reply With Quote
Old   March 5, 2013, 12:54
diamondx's Avatar
Ghazlani M. Ali
Originally Posted by Far View Post
Ahmed body?
You mean FAR body
Regards,
Ali
Old   March 5, 2013, 13:09
Far
Sijal
Originally Posted by diamondx View Post
You mean FAR body
Hehe
You have same case? Attach representative geometry
Old   March 5, 2013, 13:12
Luca
What does it mean ahmed body??
p.s.:thanks Ali for the quick reply )
Old   March 5, 2013, 13:19
Far
Sijal
It is automotive research model.
Old   March 5, 2013, 13:27
Luca
how have you understood that is related to automotive? :S impressive )) btw it's a project for the Sauber team. They want to study the flow within the diffuser of a F1 car. I started yesterday to work with ICEM, it's quite tricky :S I am trying to build a structured mesh around the body. But I don't understand if the blocks have to cover the whole body, how many blocks I have to use and how to create a block around the sideplate...
Old   March 5, 2013, 13:50
Far
Sijal
Actually i guessed it due to two reasons: distance from lower boundary and shape.
Either you can follow the full hexa mesh method http://www.cfd-online.com/Forums/ans...mesh-legs.html or look for thread in this forum on hybrid mesh (Diamondx has done the wonderful job in this area, look for hi threads)
Old   March 6, 2013, 16:29
Luca
Thanks a lot for the video!! it's very helpfull. However I have a dummie question...the software will create the mesh only inside the blocks?? I mean, in my model I have to avoid any blocks inside the body?? Thanks
Old   March 6, 2013, 23:38
Far
Sijal
No it will not create mesh inside the body if you don't want.
Old   March 7, 2013, 06:41
Luca
Ok I understand. In my case I don't want to mesh inside the body and I associate the blocks inside the body with the solid part. After that before to compute the mesh I deselect the solid part. is it the right way??
Old   March 7, 2013, 06:50
Far
Sijal
Yes. You have two options either you make it solid (and uncheck it when making mesh) or delete it. I usually prefer the first approach.
Another advantage of having solid is when you want to make the o-grid around the vehicle. In this case you just select the solid and make the o-grid around it.
Old   March 9, 2013, 10:45
Luca
Ok I used o-grid to split the blocks around the body and it worked well well thx. btw I have a further problem, I wan't to improve the mesh in the junction between the ramp and the side-plate of the diffuser (red circle). I would like to use unstructured mesh for the red triangle block but I don't understand how I can do it.
Old   March 9, 2013, 10:56
Far
Sijal
Use Y-block to mesh triangle region.
http://www.cfd-online.com/Forums/ans...tices-why.html
Old   March 9, 2013, 11:11
Luca
ok thx for the link. however I'd like to know if it's possible juest to select a block and impose to use different elements
Old   March 9, 2013, 14:19
Far
Sijal
Yes you change type of block to swept, free etc. Go to edit block and set block type.
Old   March 10, 2013, 12:52
Luca
in order to replicate the solution in the red circle how can I do? I don't understand if I have to modify the block associated to the fluid or the block associated to the solid.
Old   March 12, 2013, 17:20
Luca
I can't still solve the problem of the elements in the corner of the side plate. I tried with Y-block but it doesn't solve the problem. I uploaded 2 pictures, one of the blocks and one of the mesh. Can you give me some suggestions?? thanks
Old   March 12, 2013, 17:58
Far
Sijal
is it symmetric or full model?
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts a.habibi ANSYS Meshing & Geometry 5 October 4, 2012 05:10
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
3d mesh of bluff body for LES Lukasz Mosakowski FLUENT 4 January 17, 2006 23:09
