[ICEM] Blocking Strategy For a simple Box
Like Tree5Likes
  • 3 Post By diamondx
  • 2 Post By Far
Old   February 2, 2013, 10:53
Default Blocking Strategy For a simple Box
Tarantino
Tarantino is on a distinguished road
Hello
I am new in this forum and quite new with ICEM.
I blocked the enclose geometry in different ways, but I can not achieve a good quality! the Box has two circle outlet and the geometry is really simple. As I saw there are so many expert people here in ICEM meshing which is of course this is really simple and easy for them to mesh, I am kindly ask to offer me the best blocking strategy for this geometry types. As I saw that the members asking to enclose the geometry in order to help better, you can download the geometry below.
Many thank all of you who will help me.
Geometry Download: 60 KB
http://www.uploadmb.com/dw.php?id=1359820013
Tarantino is offline   Reply With Quote
Old   February 2, 2013, 11:45
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
I don't have pc right now, but this a very basic geometry here are the step to do a nice blocking:
1- create an initial block.
2- create an ogrid inside the block you created in step 1. you have to select the bottom face (ground) to when creating the o-grid. (Because the two shares the same face)
3- make the splits to capture the circles, don't forget to add o-grid inside those because of the circular shape. Come back here if you still found it difficult, i will remotely connect to my pc in lab and help you do it.
asal, amin_gls and Tarantino like this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   February 2, 2013, 12:23
Default 3D - Box
Far
Sijal
Simple Box <---> Simple blocking .
asal and Tarantino like this.
Old   February 2, 2013, 16:58
Tarantino
Hello and thanks for your sample block.
Do you see the quality and scan plane of the mesh!
why you add some curves to the geometry? to assign theses curves for your o-grid? Is there any way that the o-grid don't go along the hole geometry? when we have no any cicle hole in the other wall, then why o-grid should go throw the hole walls?
anyway, thanks for your time.
I am looking for an intelligent block strategy to avoid cutting hole the blocks in so many peaces!
Old   February 2, 2013, 17:11
Far
Sijal
Yes and you need to set the edge shape through edit edge commands. You have to do it if you need perfect mesh .
Yes
Why not? There is no effect of extending blocking to other wall. It is not going to change the boundary conditions there so no worry.
I would love to see other methods with smart blocking. Please do share it...
Old   February 2, 2013, 17:26
Tarantino
Hello.
How can I use the Edge edit command to improve the quality in this case?!
could you please let me more.
It would be great, if others share ideas about the blocking.
Old   February 3, 2013, 08:15
Astio Lamar
asal is on a distinguished road
Try this one!
http://www.uploadmb.com/dw.php?id5
asal is offline   Reply With Quote
[ICEM] o grid blocking strategy? icemaniac178 ANSYS Meshing & Geometry 14 March 19, 2013 23:18
[ICEM] Blocking strategy ICEM krembil ANSYS Meshing & Geometry 9 November 23, 2012 05:49
[ICEM] Complicated geometry blocking strategy sidd ANSYS Meshing & Geometry 1 October 3, 2012 13:34
[ICEM] Advice on a blocking strategy pipolaki ANSYS Meshing & Geometry 13 July 23, 2012 17:46
[ICEM] Blocking strategy for inclined plate cbisw ANSYS Meshing & Geometry 3 May 27, 2011 08:17
