Home > Forums > ANSYS Meshing & Geometry
[ICEM] problem in meshing
Like Tree1Likes
  • 1 Post By Far
Old   February 4, 2013, 10:39
Default problem in meshing
tmeysam92
tmeysam92 is on a distinguished road
Hi all,
i meshed a geometry(Fig.1), but the mesh quality is not good.
can someone please help me?
thanks in advance.
tmeysam92 is offline   Reply With Quote
Old   February 4, 2013, 11:36
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
I didn't quit understand the geometry. But this is blocking according to my perception.
Far is offline   Reply With Quote
Old   February 4, 2013, 12:17
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
there you go:
just create your block without the extended part then extrude...
https://dl.dropbox.com/u/35161486/ali.zip
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   February 4, 2013, 12:53
tmeysam92
thank you very much Far.
i did not understand how you make second circle in the middle of cylinder?(see the picture)
could you please tell what did you do exactly?
Old   February 4, 2013, 13:00
diamondx's Avatar
Ghazlani M. Ali
after he initialized the first o-grid, he created a second one with a offset of 0.2 . then a second one with an offset of 1...
Regards,
Ali
Old   February 4, 2013, 13:01
diamondx's Avatar
Ghazlani M. Ali
i guess he also added curve in the outer surface to better associate. with the project curve to surface tool
Regards,
Ali
Old   February 4, 2013, 13:11
Far
Sijal
Originally Posted by diamondx View Post
there you go:
Ali, you have made it easy to understand the extrude and rotate in blocking and edit mesh tab.
Yes
Yes. For both I used default settings (offset = 1). Then made the association and snaped vertices. After that I used vertex command to align other parallel vertices. Then made second o-grid and splited block at the center where wall is located. Also I changed the material of unwanted blocks as void (used index control to select the appropriate blocks).
tmeysam92 likes this.
tmeysam92
thank you Ali.
as i am using icem cfd interactive mood (i mean running icem in ansys meshing using multizone), so i do not have permission to modify the geometry.beause when i meshed in icem cfd, then in returing to ansys meshing there will be errors.
but the same circle is in your files, how did you create that? you did like Far?
Old   February 4, 2013, 13:14
diamondx's Avatar
Ghazlani M. Ali
yes, just like FAR
Regards,
Ali
Thread Tools
Trackbacks are On
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 14 January 11, 2016 07:17
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 08:21
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 20:03
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
