[ANSYS Meshing] "The mesh file exporter does not support overlapping geometry in named selections"
Old   February 4, 2013, 17:42
Default "The mesh file exporter does not support overlapping geometry in named selections"
blacksoil2012 is on a distinguished road
I'm meshing rotor/stator type geometry in ANSYS Workbench Meshing.
First, I grouped the rotor/stator geometry inside Design Modeler so that they form "multi-body part"; I was hoping to get automatic conformal mesh when I do the meshing inside Workbench meshing.
Then inside Workbench meshing, I did the meshing; perfectly, the interfaces got the same mesh. And then I named them in "Named Selections" such as "interface_rotor_domain" and "interface_tank_domain". And then, when I tried to export this mesh to a Fluent mesh *.msh file, the error message pops up:
" The mesh file exporter does not support overlapping geometry in named selections. ...."
I checked again and again, and I even deleted the old named selections to re-do the naming to make sure I'm not naming the same geometry to multiple names. But still, the error message persists.
I had the feeling that the "multi-body part" is causing trouble here... as a previous post by PSYMN suggested, maybe we shouldn't use "multi-body part"; rather, just mesh the two bodies separately.
by the way, I am using ANSYS 14.0.
I feel ANSYS should be smarter than this. This is really annoying.
blacksoil2012 is offline   Reply With Quote
Old   February 4, 2013, 18:10
update:
I went back to unbundle my rotor and stator bodies, meaning let them be separate parts rather than one "multi-body part", and now I can have separate named selections for each side of the interface and there is no "mesh file exporter does not support overlapping geometry" error when I export to a *.msh file.
Then again, to be able to generating matching mesh for the two sides of rotor and stator domain, as PSYMN once suggested, we have to either use "match" or specify the same size control on them. Not exactly "conformal" mesh, but "aligned" mesh.
Old   October 30, 2015, 07:02
kemin ali
kemin is on a distinguished road
how to separate two parts, I have the same problem?
Regards
kemin
kemin is offline   Reply With Quote
Old   October 30, 2015, 08:03
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
Regards
kemin
If you're using Design Modeler to draw your geometry, make sure you have separate parts and bodies.
JuPa is offline   Reply With Quote
Old   October 30, 2015, 10:27
Default I got it
kemin ali
Great thanks, I got it. it should be like this:
select body/(right click) form new part
Regards
kaiming
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
