[ICEM] Gas separator blocking
Old   March 5, 2013, 07:38
Default Gas separator blocking
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear all,
I need to do the blocking for such a gas separator:
Blocking in y-direction seems to be pretty straight forward. But how would you do the blocking of in- / and outlet pipes? I am not sure how to connect standard pipe blocking with the actual separator blocks...
I am happy about any ideas...
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   March 5, 2013, 08:03
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
agdb file doesn't have any geometry. Can you upload .tin file instead of agdb!!!
Far is offline   Reply With Quote
Old   March 5, 2013, 08:07
Philipp
Ok, I allways use the "workbench import" and import the geometry from the agdb file.
Anyway, here it is!
ICM_tin.zip
Old   March 5, 2013, 11:10
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
For the sake of an easy blocking , can't you simplifly the parts i highlighted in red
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 5, 2013, 13:11
Philipp
I already put round plates at top and bottom. I don't see any problem at these locations. What do you mean?
Old   March 5, 2013, 14:08
diamondx's Avatar
Ghazlani M. Ali
if you have too many elements in the up for example, they will be squeezed giving you then a bad quality. you have to add some quarter grid there. like in the picture below
Simplifying the geometry will not require you adding grid
Regards,
Ali
Old   March 6, 2013, 03:50
Philipp
Why not like this?
Old   March 6, 2013, 08:04
Philipp
Hi again,
What do you think of this?
1st step -> large ogrid along the y-direction
2nd step -> cut edges of long block above and below the inlet
3rd step -> create ogrid at inlet pipe. The orange line / arrows show the way of the ogrid.
Old   March 6, 2013, 08:08
Far
Sijal
perfect
Old   March 6, 2013, 08:11
Philipp
No way, are you kidding?
So there is no way I can keep the o-grid of the inlet "inside", right? I have to let it leave on the backside in the same plane? I would prefer to have edges more or less parallel to the flow...
Old   March 6, 2013, 10:12
diamondx's Avatar
Ghazlani M. Ali
what you did is good
Regards,
Ali
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
