-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Normal to edge split (http://www.cfd-online.com/Forums/ansys-meshing/112985-normal-edge-split.html)
Bollonga February 9, 2013 05:23
Is there a way to split a block from prescribed point in the normal direction to the edge?
Icem only allows to do it in one of the three cartesian direction, as far as I know.
That would help me a lot in making simpler blocks in a faster way.
Thanks!
Far February 9, 2013 07:04
you can adjust your vertices later with vertex setting commands
Bollonga February 9, 2013 08:32
Originally Posted by Far (Post 406868)
can you adjust your vertices later with vertex setting commands
I know, but I wanted to know if there was a way to do it directly. I'll do it modifing vertices then.
