-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] problem in ICEM CFD (http://www.cfd-online.com/Forums/ansys-meshing/113171-problem-icem-cfd.html)
tmeysam92 February 14, 2013 01:22
problem in ICEM CFD
1 Attachment(s)
Hi all,
i want to mesh a multi body part in ICEM CFD interactive mood, i mean meshing directly in ansys meshing, but i don not know why it opens 9 times icem cfd for one of the parts.(see the picture)
tmeysam92 February 14, 2013 03:41
1 Attachment(s)
in below pictures, i meshed one time in icemcfd then i closed it, but again it writes 8 attempts left, and the icem cfd opens again!!!
why ???
thanks in advance.
jrunsten February 14, 2013 03:50
The mesher tries meshing with fines settings because the shape checking failed, I think
tmeysam92 February 14, 2013 04:06
thanks for your reply
if i mesh just one part, it never attempt 9 times, but if i mesh this part in a multibudy part, it will attempt 9 times.
jrunsten February 14, 2013 04:18
It is much easier to mesh just one bodies than to mesh a multibody part.
By the way, you don't have a multibody part to begin with. I see 8 separate bodies in the tree.
tmeysam92 February 14, 2013 04:31
you right . i have 8 separate bodies. i use multizone method for meshing. then i activate using icemcfd. in body selection menu, i selected 4 parts, so when i update meshing, it opens icem cfd, and i should mesh every part in icem cfd, but when i mesh one of the parts in icem cfd and converted to unsterauctured, then i closed, but it again opens the icem cfd for that part again, and it happens several times,
now i have a question, why it attempts 9 times, while i meshed accurately that part in icem cfd?
binoyjjohn August 11, 2013 13:53
The mesher is trying to mesh the geometry. I will stop after 8 attempts. Try changing the mesh settings.
