February 17, 2013, 11:37 |
problem icem cfd
tmeysam92
i meshed my geometry in ICEM CFD, and it contains a cylindrical part and a nozzle part.(see the picture) the problem is that, i want to export mesh to fluent, but these two parts have different initial velocity in fluent. so how can i put different velocity for these two parts? i mean what should i do in ICEM CFD boundary condition? i have attached prj&blk&tin files. tanks in advance. |
February 17, 2013, 13:48 |
#3 | |
tmeysam92
you right, there are not two parts, i mean the cylinder and nozzle. so, you mean i should use create part tool by using "blocking material, create part" for each one??? |
February 17, 2013, 14:10 |
tmeysam92
if you look at below picture you will understand what i mean.
i want to have different initial velocity in fluent for fluid 1 and fluid 2, now what should i do?? is it right that i should use create body in geometry tab of icem cfd? |
February 17, 2013, 23:52 |
tmeysam92
February 18, 2013, 18:02 |
Simon Pereira
Rep Power: 47 |
This is one of those times when "why?" would be a great question...
You should probably not be setting two velocities. You should set the inlet velocity and the velocity in the nozzle will be calculated... If you are just trying to speed things up and initialize with closer to final velocities, then you should be using the new hybrid initialization in Fluent... It basically generates a coarse background grid and then does a rough solve to work out initial velocities through the volume. These initial velocities are applied to the real solution as a great starting point.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
[ICEM] problem with meshing in icem cfd | saurabhjoshi2011 | ANSYS Meshing & Geometry | 13 | March 12, 2013 11:27 |
Batch mode ICEM CFD parametrization problem | sportsfun | ANSYS | 0 | December 19, 2012 14:20 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
ICEM CFD 5.1 problem with tetra count | Baskaran | CFX | 2 | March 13, 2006 12:59 |
