[ICEM] question about Blocking a full scale vertical axis wind turbine |
February 24, 2015, 06:11 |
mohsen razavi
Rep Power: 11 |
Hi Everyone !
I am new to ICEM CFD. my thesis is about analyzing a 3 bladed ( NACA4415 ) VAWT. but since I am new to this software, i have some basic questions. 1- how can I Block my full sclae project correctly so that the rotating type be meshed much smaller than the static part? 2- how can I make the main circle in the images rotating ? for my simulation, i want it to be rotated 3- imagine that i blocked this 2D project correctly, is there any way to make a 3D mesh grid from that 2D. i mean can i transform my final work into 3D in order to analyze 3D project ? for more info about images : I used formatted point data to import my naca4415. then i rotated it 120 degrees and made 2 copies. then i drew a circle (my rotating area). then i drew farfield lines. i have not done any thing more. I really need your step by step help bros. please help me. Thanks. |
Horizontal Axis Wind Turbine | CFD XUE | FLUENT | 22 | May 24, 2017 12:17 |
Vertical Axis Wind Turbine | PiotrekL1 | Autodesk Simulation CFD | 3 | May 29, 2013 14:20 |
Reversed flow in Vertical axis wind turbine | Anonymized_JL1 | FLUENT | 2 | April 11, 2012 03:13 |
Vertical axis wind turbine in NUMECA | ArslanOZCAN | Fidelity CFD | 2 | July 21, 2011 05:04 |
angular velocity in vertical wind turbine | vanni | FLUENT | 1 | April 23, 2009 02:44 |
