[ANSYS Meshing] Ansys Workbench 14.0 creating 2D axi-symmetric mesh
Like Tree1Likes
  • 1 Post By evcelica
Old   February 19, 2013, 06:03
Default Ansys Workbench 14.0 creating 2D axi-symmetric mesh
Barry VRee
barryvree is on a distinguished road
Currently I am working on a problem involving rapid depressurization of CO2 in a pipe. This is clearly an axi-symmetric problem.
I would like to simmulate this problem using CFX. I know about the fact that CFX cannot handle truly 2d bodies and therefore I created a wedge of the pipe for meshing purposes.
However, in the ansys workbench 14.0 mesher, it is not possible to use the "extruded 2d mesh" functionality as a "mesh strategy".
How can I now create a mesh of this wedge of the pipe that has one element thickness?
Thanks in advance!
barryvree is offline   Reply With Quote
Old   February 19, 2013, 06:34
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
I cannot recommend this technique.
If you really want only 1 cell along the wedge, the segment would have to be very thin (lets say <5°). This results in a cell with the same small angle at the center of your wedge.
For a decent mesh quality, an angle of at least 20° (better 30°) is required.
Either you choose a wedge with this angle and have lots of unnecessary cells or you use Fluent, which can handle real axisymmetric domains.
flotus1 is offline   Reply With Quote
Old   February 19, 2013, 06:53
Barry VRee
Thanks for your reply,
The reason I'm would like to use CFX is the fact that it contains CO2 in both gas and liquid form which is needed for my simulation of rapid depressurization when liquid CO2 will vaporize.
Old   March 9, 2013, 04:00
flame_vivi is on a distinguished road
I m doing combustion in a coaxial cylinder geometry and I m using CFX. I created a slice of 3°, but I have the same problem of you, in workbench 14. I'm struggling to create a single element through the thickness, "manually". Have you managed to find a solution for you prob?
thanks
flame_vivi is offline   Reply With Quote
Old   March 9, 2013, 04:22
flotus1's Avatar
Alex
Reading the posts in this thread again, you will see that a slice of 3° is not a good idea.
Old   March 9, 2013, 04:55
Yes I guess so. I gota get started with a 2D simulation, or at least a quasi-2D, though, especially because the grid domain is quite big. So I was wondering how to handle 2D axial symmetric geometries in CFX.
thank you anyway
Old   March 9, 2013, 10:01
flotus1's Avatar
Alex
The only thing you could do is to remove a part of the domain near the axis of rotation and put a symmetry boundary condition at the newly created face.
This prevents the problem with the sharp angle at the center.
Nevertheless, it also alters the shape of the fluid domain.
CFX is simply not the tool of choice for planar and axisymmetric problems.
Old   March 11, 2013, 15:26
I agree. Thank you for the reply anyway.
Old   March 13, 2013, 15:44
Question
René
rene78 is on a distinguished road
But imagine one still wants to create a mesh of 1 element thickness? I have the same problem as the original poster (me using V13). The function "extruded 2d mesh" doesn't seem to be available anymore.
Is there anybody, who could give me a hint on creating such a mesh?
rene78 is offline   Reply With Quote
Old   March 16, 2013, 01:58
hi rene,
I know small angles are not the best choice for a good quality mesh, but if you want to give it a try, go for a structured mesh. If you have the same number of nodes along the edges of your angle, you can be sure that there will be only one element through the thickness. CFX is not a 2D solver so the solution will be calculated on x,y,z anyway, but the fact that there is only one element on the third dimension, let you see the problem as 2 dimensional. I hope I ve been clear.
Old   April 26, 2013, 07:09
Default 2D analysis in CFX and Fluent
  #11
Namsu
Usman15 is on a distinguished road
I am modeling turbulent non-premixed combustion in a Can Combustor with and without swirl induced recirculation zones. I am using use CFX and Fluent and comparing the results. For Flueut I have made a 2D grid while for CFX a thin wedge of 1 degree. I have following confusions:
· While making a thin wedge grid on ICEMCFD I gave rotational periodicity along the axis of rotation (Mesh→Global mesh parameters→Define periodicity→Rotational periodic). So that CFX take it as an axisymmetric problem. Then in CFX I am using symmetry BC for flow without swirl and periodic BC for flow with swirl. Is it the right approach? Or should I make the grid without rotational periodicity and then give the same BC in CFX?
· How can we apply periodic BC in CFX? Is it in domain interface?
· If in the third dimension instead of one cell I take two or more layers of cells, what effect will it have on the results?
Many Thanks in advance.
Usman15 is offline   Reply With Quote
Old   May 1, 2013, 23:43
Erik
evcelica is on a distinguished road
like Michelle Obama said, you can remove the central region of your mesh and use symmetry. If a small enough volume is removed it will not effect your solution.
flotus1 likes this.
evcelica is offline   Reply With Quote
Old   October 14, 2013, 02:40
Smile CFX can handle axisymmetric problems
  #13
Petr Jurcicek
Peter023 is on a distinguished road
Hi everyone,
according to my experience there is a way how to handle the axisymmetric simulation in CFX.
The geometry can be rotated as little as 1deg around its axis. In the ANSYS meshing tool, the necessary mesh smoothing is applied first and the meshing method is set to "sweep" (Mesh->Insert->Method) with manually specifying the two periodic boundaries (left, right). The number of divisions for the sweep method is 1. Its a good practice to name these two boundaries, e.g. symmetry_a, symmetry_b. Another named selection should be "axis" which is the geometry's axis :-)
In CFX then, the symmetry boundaries will be symmetry_a and symmetry_b. The rest of the setting is as usual. The quantities, e.g. mass flow will be 1/sweep angle of the real mass flow.
Note: Fluent loads pure 2D geometry but according to my knowledge, the geometry is "sweeped" or extruded in Fluent (1 deg) instead. Generally, the method used in fluent and CFX is analogical but Fluent makes it easier.
Hope this helps. Contact me in the case of any doubts, please. The above described method has only one disadvantage: the sweep meshing is awfully slow!!
Cheers,
Peter
Peter023 is offline   Reply With Quote
2-d, axisymmetric, co2, depressurization, mesh control
[ANSYS Meshing] Multi-size mesh generation in ANSYS 12.1 Workbench nsakib520 ANSYS Meshing & Geometry 0 April 6, 2012 15:19
ansys imports icem-cfd ansys mesh adam2008 ANSYS Meshing & Geometry 0 March 5, 2011 08:40
2D mesh by ANSYS Workbench 8.1 Dome CFX 4 June 6, 2005 06:20
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
