-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Merge blocking (http://www.cfd-online.com/Forums/ansys-meshing/113415-merge-blocking.html)
Bollonga February 19, 2013 10:10
Merge blocking
Hi everybody,
I've made a complex blocking in a reduced volume surrounding a 3D body and I'd like to merge this blocking in a larger domain that already has a blocking.
I've tried to directly import the small blocking in the larger domain but it just replace the former one. How can I merge these blockings without losing any of them?
I haven't found any useful info in the ICEM guide.
Thanks
energy382 February 19, 2013 12:59
Originally Posted by Bollonga (Post 408760)
Hi everybody,
Thanks
Use sub-topo
Bollonga February 21, 2013 05:50
Originally Posted by energy382 (Post 408793)
Use sub-topo
Thanks for the advice.
Now I've imported one sub-topology into the former one. The problem is that I have common surfaces and edges with different meshes from each of the sub-topologies. Also I can't view both meshes at the same time.
How can I create a single mesh for both sub-topologies?
diamondx February 21, 2013 07:59
right button click on one topology and select merge...
