Home > Forums > ANSYS Meshing & Geometry
[ICEM] Negative Determinant
Old   February 20, 2013, 11:59
Default Negative Determinant
saisanthoshm88 is on a distinguished road
I've exported a mesh generated in Ansys meshing to the ICEM Input File(.prj) format.
Then I imported it into ICEMCFD. When I checked the determinant of the imported mesh in ICEMCFD, I found it to be a negative value.
Usually within workbench, I check the orthogonal quality, skewness and Minimum corner angle for the mesh and I found them good -
Orthogonal quality - 0.15
Skewness - 0.93
Minimum corner angle - 60 to 162 [deg.]
But the problem is with the negative determinant which I checked in ICEM after importing the mesh there.
Could some one please clarify this
Also is there a way to check the "equivolume skewness" in ICEMCFD I mean I'm not sure if the metric "equiangle skewness" of ICEM is in comparison with the skewness measure of Fluent.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Thread Tools
Trackbacks are On
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 12 December 12, 2011 05:16
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
