Home > Forums > ANSYS Meshing & Geometry
[ICEM] Move vertices not associated with a point or curve
Old   February 21, 2013, 08:15
Default Move vertices not associated with a point or curve
Javi
FJSJ is on a distinguished road
I want to move a vertex that is not associated with any edge or point. This vertex is located on a circular area (x-y plane). I have the same number of vertices on the upper and lower semicircle. I want to align them in the direction x, for this I use Set Location and no problem. But if I want a vertex of the upper semicircle is at the same distance (y-axis) of the center of the circle to a vertex that is in the lower circumference ... how can i do?. I can use the Measure Distance .. but there is no better way?
FJSJ is offline   Reply With Quote
Old   February 21, 2013, 08:30
Javi
Here there is an example
Old   February 21, 2013, 10:43
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
align them in x direction, then try giving them same length
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   February 21, 2013, 11:44
Javi
thanks diamondx. I did that. Wondered if there was any automatically. I think it would be interesting an option like this.
Thread Tools
Trackbacks are On
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 8 July 3, 2014 10:54
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
CFX Post: Problems with moving point cloud for changing time steps spatialtime CFX 0 December 7, 2009 05:56
[ICEM] Smoothing a curve lost.identity ANSYS Meshing & Geometry 6 July 13, 2009 05:23
How to maintain spacing along a new curve? KB Main CFD Forum 2 June 5, 2007 16:45
