February 19, 2013, 11:10 |
Merge blocking
Francisco
Rep Power: 15 |
Hi everybody,
I've made a complex blocking in a reduced volume surrounding a 3D body and I'd like to merge this blocking in a larger domain that already has a blocking. I've tried to directly import the small blocking in the larger domain but it just replace the former one. How can I merge these blockings without losing any of them? I haven't found any useful info in the ICEM guide. Thanks |
February 19, 2013, 13:59 |
#2 | |
Christoph
Rep Power: 17 |
February 21, 2013, 06:50 |
Francisco
Rep Power: 15 |
Thanks for the advice.
Now I've imported one sub-topology into the former one. The problem is that I have common surfaces and edges with different meshes from each of the sub-topologies. Also I can't view both meshes at the same time. How can I create a single mesh for both sub-topologies? |
blocking, blocks, import, merge, open blocking |
Display Modes | |
[ICEM] Problem to load the blocking | biasilveira | ANSYS Meshing & Geometry | 2 | February 24, 2013 23:04 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 04:13 |
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 18:27 |
[ICEM] Merge mesh - non manifold vertices | BrolY | ANSYS Meshing & Geometry | 4 | October 30, 2010 23:07 |
about merge mesh | lian | Main CFD Forum | 3 | February 29, 2008 11:47 |
