Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Hollow hemisphere: Why not sweepable?
Old   February 21, 2013, 13:00
Default Hollow hemisphere: Why not sweepable?
siw
Stuart
siw will become famous soon enough
Can anyone tell me why ANSYS Meshing does not think a hollow hemisphere (see image) is a sweepable body. I would have thought it could be swept from internal to external spherical surfaces but it will not.
Thanks.
siw is offline   Reply With Quote
Old   February 21, 2013, 15:08
mjgraf is on a distinguished road
a revolve sweep or extrude by rotation would work, i think. Not sure what would happen at the 0-360 interface, if it would merge those nodes/faces.
Originally Posted by siw View Post
Can anyone tell me why ANSYS Meshing does not think a hollow hemisphere (see image) is not a sweepable body. I would have thought it could be swept from internal to external spherical surfaces but it will not.
Thanks.
mjgraf is offline   Reply With Quote
Old   February 21, 2013, 17:26
siw
Stuart
mjgraf, are you referring to DesignModeler commands? Because as you can see I have made the geometry in DM (by two spheres using a smaller one to slice out the material from the larger one and then a slice by place to cut it in half). The mesh in the image is with MultiZone.
I'm simply asking about why this is not a sweepable body in Meshing.
Old   February 21, 2013, 19:00
not sure, don't use DesignModeler/Workbench
Old   February 21, 2013, 19:07
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i guess he does not see it as a sweepable body because of the way you created your geometry. if you had used a rotate or an extrude option, things will have been different. I'm just guessing here...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   February 22, 2013, 03:17
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
From the picture you attached, it looks swept to me?
I tried as well and managed to get a swept mesh with "Src/Trg Selection" set to Manual or Automatic Thin
jrunsten is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ANSYS Meshing] Non Sweepable bodies b.shuvayan ANSYS Meshing & Geometry 21 March 23, 2015 07:41
[ANSYS Meshing] Inlet Pump - Creation of sweepable bodies DarkRudy ANSYS Meshing & Geometry 5 January 28, 2013 08:58
Expanding and contracting hemisphere LvK FLUENT 0 August 26, 2010 02:35
Hollow Cone Injection Problem JaC FLUENT 1 December 3, 2009 04:03
hemisphere in channel flow kirill FLUENT 3 September 16, 2004 11:51
