[ANSYS Meshing] problem about the geometry and meshing of the airfoil
Old   February 10, 2013, 22:38
Default problem about the geometry and meshing of the airfoil
yileihe1989 is on a distinguished road
Hey
When I was trying to establish the mesh, I ran into this problem: some abnormal mesh appeared.Does somebody know why this happened?
And the other thing is what the green point and the arrow stand for in the trailing edge of the airfoil. I imported the airfoil from coordinate file and the begin point is (1,0).
Thanks!
yileihe1989 is offline   Reply With Quote
Old   February 11, 2013, 04:00
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Not sure about the weird mesh. Supply an archive of the project if you want someone to look at it.
The second question is easier. It is just a coordinate system for the 3d curve
jrunsten is offline   Reply With Quote
Old   February 24, 2013, 06:18
Default Re
nauman hashmi
nauman55 is on a distinguished road
the problems seems with a bad vertex or curve association check that out.
regards
nauman55 is offline   Reply With Quote
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) fluent_beiyo ANSYS Meshing & Geometry 8 April 26, 2014 04:55
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[ANSYS Meshing] Help - Meshing 2 Surfaces On A 2D Geometry Ali_M ANSYS Meshing & Geometry 4 March 29, 2011 03:01
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Problem meshing turb. blade tip clearance geometry Balu FLUENT 0 June 7, 2008 21:10
