Home > Forums > ANSYS Meshing & Geometry
[ICEM] 3d blocking - divergence in Fluent
Like Tree1Likes
  • 1 Post By Far
Old   February 22, 2013, 14:51
Default 3d blocking - divergence in Fluent
jyh
jyh3134 is on a distinguished road
Hi guys, I'm stuyding a fairing for Human Powered Aircraft.
I managde to make hexa grid using ICEM-CFD. (see picture)
I use O-grid around fairing, and set 1st cell distance to 0.04 for y+<=1.
I checked 2x2x2 determinant (above 0.7) , and angles(above 18 deg).
and I convert to unstructured mesh, and set BC.
After I ran the simulation in Fluent, the residuals of continuity diverged at 200~300 iterations. (check, scaling also done)
The flow condition is
U=8m/s
k-omega SST (even laminar model failed, too)
others : default for quick trying.
I'd like you to see ICEM files for detail, I linked it below.
https://www.dropbox.com/s/h3drel9swnyfb1l/diver.zip
(You should uncheck 'SOLID' part whick is inner block in fairing.)
I hope someone helps me for finding my fault.
best&regards.
jyh3134 is offline   Reply With Quote
Old   February 22, 2013, 19:18
Default solve
jyh
I solved the problem by regenerating new mesh by myself.
The aspect ratio caused this problem i think.
Thanks for your interest.
Best & Regards
Old   February 23, 2013, 05:13
Far
Far's Avatar
Sijal Ahmed Memon (turboenginner@gmail.com)
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
Look on this blocking. Fairing3 has o-grid in the wake region.
https://dl.dropbox.com/u/68746918/Fairing2_Far.zip
https://dl.dropbox.com/u/68746918/Fairing3_Far.zip
Best Regards
Far
http://cfd-consultancy.webs.com/
Far is offline   Reply With Quote
Old   February 23, 2013, 07:20
Default Thanks Far!!
jyh
Above all, I'm very glad to receiving your help.
I like your first suggestion due to easy being easy to understand blocking.
You should split around SOLID part and wake region with o-grid
after split tail of fairing with o-grid(for inner circle), right?
and some other blocking strategy of yours are very helpful for me.
It's well worth enough to run simulation again with new mesh on your suggestion, and I'll let you know the results in Fluent.
The simulation failed again.
So I'm certain that working in geometry had some error.(dividing parts or rapiaring geometry topology,etc.)
So I need to make new blocking again like yours with another geomety which was worked well.
It's very similar to previous one, but not identical, so can't match blk file.
Anyway, Thanks for your help again, and I have a question to you personally.
Are you working in ANSYS inc? I know SIMON is, and think that you should be.
I believe that the greatful help and support of yours(likes threads, YOUTUBE videos, etc.) is one of the strengths of ANSYS.
Best& regards
Old   February 23, 2013, 08:35
Far
Far's Avatar
After making o-grid around surface (fairing), I made split at some lengths downstream. Then I chose those downstream blocks (use index control) and made the o-grid. Blocking may look like something complex due to many edges.
No need to re-create blocking. If your geometry is similar, you can use older blocking with minor adjustments.
Exporting blocking/mesh for a similar geometry
Are you working in ANSYS inc? I know SIMON is, and think that you should be. I believe that the greatful help and support of yours(likes threads, YOUTUBE videos, etc.) is one of the strengths of ANSYS.
I hope, one day I will be there...
PS : what are the units and boundary conditions you are using... Is there any thread in Fluent section?
Best Regards
Far
Old   February 23, 2013, 10:59
jyh
I used BC with Velocity Inlet(upstream, top,bottom,side) , Pressuare Outlet and symmetry. Because the flow is incompressible. ( U=8m/s)
Re is about 1.5e6, so I used k-omega SST turbulent model.
Thanks for kind explain, the index control still isn't familiar with me.
I'll try it again tommorow.(now I'm busy to write onther report.)
and also wish you get a reward for being so helpful. You'll be there I'm sure.
BTW is there more learing material or examples about 3d blocking?
I read tutorial manual and watched videos(ANSYS inc, yours(turboengineer, right?)), lots of threads in this forum and managed to try them.
But still I can't make structured mesh with the geometry(my final goal) of my study.
someone probably can tell me that the theoretical training already has done, that's problem about my experience and efforts.
But I want to know how you can improve your blocking skills. and i think many people want to know, too.
Best& Regards
Old   February 23, 2013, 11:24
Far
Far's Avatar
Did you check the mesh quality in Fluent?
You made the model in mm or m?
You keep (and other) on giving me geometries
Best Regards
Far
Old   February 23, 2013, 11:42
Far
Far's Avatar
I have planned to work on following cases (from geometry to post processing):
1. Wing body (different configurations)
2. Automotive (Ahmed body)
3. Centrifugal and axial compressor
4. Centrifugal pump and volute
5. Wing
6. Heat transfer (preferably heat exchanger and film cooling in gas turbine)
7. Vertical and horizontal axis wind turbine
8. Formula one
9. Any thing else in demand
We plan to provide high quality solution from scratch to final report. I am also planning to add T-grid, ICEM tetra surface meshing (Patch dependent and patch independent). I also want to attempt full hexa meshing on Helicopter and complex air-craft. We will put ready-made solution and also on call one-to-one sessions.
cfd seeker likes this.
Best Regards
Far
Old   February 23, 2013, 12:07
cfd seeker is on a distinguished road
5. Wing
8. Formula one
Nice idea . What is the name of your company/project so that we can advertise you
cfd seeker is offline   Reply With Quote
Old   February 23, 2013, 12:23
jyh
https://www.dropbox.com/s/fza18hdf6n...0for%20HPA.zip
my recent prj, tin file is here and unit is mm. It made no problem.
quality of old one in Fluent I checked,
Minimum Orthogonal Quality : 2.29615e-05 !!
Maxiimum Aspect Ratio : 1.24145e+06
This value is not equal to the value I check quality of converted uns mesh in ICEM-CFD (above 0.3)
How it can be???
By the way..
Oh, most of projects you listed are present in your Youtube channel.
I'll try more and more your projects even something seems to be not to associated with my study. Everything is helpful I think.
Old   February 23, 2013, 12:31
Far
Far's Avatar
These tutorials are available, but I want to increase their quality 10 times with written material and voice.
Mesh is too fine. It should not exceed 0.5-0.6 million.
Best Regards
Far
Thread Tools
Trackbacks are On
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 13 June 25, 2012 11:59
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 0 May 1, 2011 09:45
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
