February 14, 2013, 23:41 |
Problem to load the blocking
BIANCA SILVEIRA
Hello everyone!
I'm working with similar geometries of Hydrocyclones (Bradley and Rietema) in ICEM 14.0, and I already created the blocking to the first one. Using the same .blk generated for the first geometry to the second one, when I import it, the blocking doesn't load the information: Loading blocking file "C:/[...]/BP_MESH2/project1.blk" Mesh size: NODES = 0 QUADS = 0 HEXAS = 0 And when I tried to 'save as' the .blk file, on the first geometry, the window information informs this problem: error copying "C:/[...]/BP_MESH1/blockingfinal.blk": no such file or directory Previous blocking file saved as file blockingfinal.blk0 Writing blocking file {C:/[...]/BP_MESH1/blockingfinal.blk} This files are created, but with the same problem of the first one! What I need to do? |
February 19, 2013, 13:41 |
Christoph
Rep Power: 17 |
I once had the same error. Try to save the project or even blk in another (local) directory/,folder. Afterwards, you should be able to save the file to your common directory.
February 24, 2013, 22:04 |
BIANCA SILVEIRA
The problem remains the same!
There is another way to solve this? |
load libudf problem | alfred | Fluent UDF and Scheme Programming | 24 | October 31, 2013 23:53 |
Load unstructured hex-mesh as blocking in icemcfd | korni | ANSYS Meshing & Geometry | 4 | July 21, 2010 17:40 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Blocking problem with ICEMCFD | Charbonnier | CFX | 1 | November 30, 2006 13:41 |
