Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] split into concentric cylinders
Like Tree2Likes
  • 2 Post By Gweher
Old   February 26, 2013, 05:37
Default split into concentric cylinders
Govindaraju
kmgraju is on a distinguished road
Dear friends
I have a solid cylinder . I would like to split concentric circular bodies . How do split multiple coaxial cylinders on it?
Thank you
Regards
Govind
kmgraju is offline   Reply With Quote
Old   March 5, 2013, 15:10
Gweher's Avatar
Gwenael H.
Gweher is on a distinguished road
There are different options you can use within DM. One way is to use the slice option using the following steps:
1) Select a sketching plan (in my case XY)
2) Draw a concentric circle, prescribe the diameter
3) Select Tool>Freeze (so you can use the slice option in step 4) )
4) Select Extrude and select the sketch from step 2), under "operation" tab select "Slice Material" instead of "Add Material" (default), hit generate
-> You will have 2 separate concentric cylinders, if you need multiples you can just draw more concentric circles in step 2) to generate the number of slices you want.
haider and jumaah like this.
Gweher is offline   Reply With Quote
Thread Tools
Trackbacks are On
Test Case: Laminar Flow Between Rotating Concentric Cylinders ebertmp OpenFOAM 4 December 3, 2012 12:54
Conduction Between Concentric Thick-walled Cylinders pongo OpenFOAM 2 October 11, 2011 14:33
concentric rotating cylinders with st-st flow having and mass transfer hossein.mashhadi Main CFD Forum 0 April 10, 2011 06:03
Flow Between Concentric Cylinders larscliff ANSYS 0 February 17, 2011 05:43
[GAMBIT] Dynamic mesh for concentric cylinders mijama ANSYS Meshing & Geometry 1 October 20, 2009 01:58
