-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] Error: Patch-conforming tetrahedron mesh failed possibly because of bad boundary mesh (http://www.cfd-online.com/Forums/ansys-meshing/114033-error-patch-conforming-tetrahedron-mesh-failed-possibly-because-bad-boundary-mesh.html)
jwillie2000 March 4, 2013 05:02
Hi Everyone,
I am trying to get a mesh with two lobes in one of the fluid regions that would be rotating. So i used the sweep method for this region and use automatic for the other two regions. When i generate the mesh i am getting the error message in the title above and i am not sure why. I know the mesh should be non-conformal at the interface between the rotating and static regions. Could this be the reason for the error? and if yes, how can i make the mesh at the interfaces non-conformal?
Thanks!
Jimmy
jwillie2000 March 5, 2013 07:35
The mesh is now okay. The problem was in the lobes fluid region. I had to first increase the defeaturing tolerance and then i had to reduce the global mesh size to 1 mm. The smallest gap between the two lobes is 1.2 mm. This solved it.
Jimmy
