[ANSYS Meshing] Error: Patch-conforming tetrahedron mesh failed possibly because of bad boundary mesh |
March 4, 2013, 04:02 |
James Willie
Hi Everyone,
I am trying to get a mesh with two lobes in one of the fluid regions that would be rotating. So i used the sweep method for this region and use automatic for the other two regions. When i generate the mesh i am getting the error message in the title above and i am not sure why. I know the mesh should be non-conformal at the interface between the rotating and static regions. Could this be the reason for the error? and if yes, how can i make the mesh at the interfaces non-conformal? Thanks! Jimmy |
March 5, 2013, 06:35 |
James Willie
The mesh is now okay. The problem was in the lobes fluid region. I had to first increase the defeaturing tolerance and then i had to reduce the global mesh size to 1 mm. The smallest gap between the two lobes is 1.2 mm. This solved it.
Jimmy |
[ICEM] Hybrid mesh for 2D boundary layer | Bigio | ANSYS Meshing & Geometry | 33 | November 18, 2019 09:15 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
