-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] smooth curves from points (http://www.cfd-online.com/Forums/ansys-meshing/114130-smooth-curves-points.html)
mrenergy March 5, 2013 17:30
Hi everyone,
when I import the coordinates of my airfoil (points, curves, and surfaces) the leading edge get somewhat sharp and doesn't pass over the points exactly when closing it up.
I imported the points only and drew the leading edge manually, it became smoother, but is very expensive in time consumed.
how can I get my airfoil smooth and accurate without hitting each point to draw it manually?
thanks in advance,
Mamdouh
darkEnergy March 9, 2013 17:08
How many curves are you importing? To get the smoothest curve you should import only 1 curve, say you import 80 points and 80 curves you're just going to get a bunch of straightlines. the more points per curves the smoother the curve.
I hope this helps.
mrenergy March 9, 2013 18:33
thank you Matt, for your reply.
for one run, I have one airfoil with two curves (upper and lower surface), 90 points each.
but I have about 30 airfoils.
actually, I imported the coordinates file as points without curves, then drew the two curves by hitting each point. the leading edge get smoother.
Besides, I used the reply script to repeat these steps for the other airfoils.
but I am asking if there is another more modern way for more complicated applications.
darkEnergy March 9, 2013 18:46
I see, it's funny I'm actually doing something very similar but instead of importing the points (because every airfoil has a different number of reference points) I only import the curve into a template file I've created that contains the far field and then I run a replay script that adds about 160 points to the curve and then does all the geometry, associating and meshing for me. Once the script is done I just double check the mesh and save. It saves so much time.
