March 9, 2013, 10:47 |
help in Global mesh setup
Arun
I was doing a jet flight mesh. i have problem with surface capturing. I like to know how to calculate or predict the value for global mesh setup. values: FF= 10 Jet=0.05 Radiator=0.03 (this part is getting meshed sometime but sometime not) please someone help me.. i was just making in random method. It will be nice if i know what i was doing. I have read the help from ICEM but it helped only little. It will be very help full if someone give me an advice. How to make it clean. Note: I can not make mesh fine because of the limitation of system configuration but if that is the only way. i can give a try Thank you |
March 11, 2013, 08:14 |
#3 | |
Arun
i dont have and geometry line in that edge. I already tried curve and proximity method but it did't help. I created separate part to mesh now but still this part is little hard to get a smooth mesh. I like to know is there any advanced method for this solution or still i'm searching in the wrong direction for the solution. please advise. Thank you |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
