[DesignModeler] How to Extrude from Circle to Square
Like Tree1Likes
  • 1 Post By jrunsten
Old   March 11, 2013, 13:33
Default [SOLVED]How to Extrude from Circle to Square
Engineer
dkx209 is on a distinguished road
I am designing a channel for the flow of water, it is a square channel having nozzles at entrance and exit. Inside it are some hurdles and cooling coils, I have designed the internal structure and now my main concern is to design the nozzle.
Like the title says, I want a geometry such as water enters from a circular hole and this passage meets the square channel at the other end. To be more clear, I want such an extrusion that its one end circular and other is a square.
Is this possible in ANSYS Design Modeler?
For reference I am attaching the sketch, this is what I want to extrude.
Side Note: I thought about using Revolution instead of Extrusion by making a sketch but the thing is other end of the extrusion will still be a circle while I need square.
Any help in this regard will be highly appreciated.
dkx209 is offline   Reply With Quote
Old   March 12, 2013, 02:33
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Split the circle into as many segments as the other profile (4), then use Skin/Loft using the two sketches as profiles
dkx209 likes this.
jrunsten is offline   Reply With Quote
Old   March 12, 2013, 06:09
Engineer
Thankyou very much for the idea, I got exactly what I wanted.
Thanks again.
Old   April 9, 2017, 11:17
Default Extrude circle and square
Raden Mirodji
Raden is on a distinguished road
Please help me i am amteur use ansys i have same proble can give mecomplete step for extrude square and circle. Thank you.
Raden is offline   Reply With Quote
Right approach for meshing of square with circle Far ANSYS Meshing & Geometry 3 October 25, 2011 10:18
[Gmsh] Cannot get the right mesh from gmsh JinBiao OpenFOAM Meshing & Mesh Conversion 2 August 31, 2010 04:51
[ICEM] Null pointer error? Mudblood ANSYS Meshing & Geometry 6 June 1, 2010 15:30
How to extrude 2D Mesh in ICEM CFD? VSB CFX 7 December 27, 2006 11:58
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
