November 24, 2011, 00:24 |
error:file can't be saved
simon bob
Rep Power: 14 |
Hi all,
I'm trying to run gambit 2.3.16 in archlinux(xorg1.11). /opt/Fluent.Inc/bin/gambit -r2.3.16 -dev X11 It worked, I could pretty much do anything with it. However, whenever I tried to save the changes(even a file with five lines,no mesh yet) ,The terminal gives a message about DbFree error,sometimes it crashes with SIGSEGV. in .trn file: Command> edge create straight "vertex.4" "vertex.1" "vertex.2" "vertex.5" Created edge: edge.6 Created edge: edge.7 Created edge: edge.8 Command> save ERROR: DbFree 296.120680 does not exist. ERROR: DbFree 336.133536 does not exist. ERROR: DbFree 336.125800 does not exist. ERROR: DbFree -111552.0 does not exist. ERROR: DbFree 240.134000 does not exist. Command> end ERROR: DbFree -111552.0 does not exist. / File closed at Mon Nov 26 04:36:50 2001, 18.99 cpu second(s), 616400 maximum memory. Total of 95.24 cpu second(s), 616400 maximum memory. I have tangled for a long period of time,have't find solution from the internet that worked! Apologize for my poor English,best regards. |
November 26, 2011, 00:36 |
simon bob
Rep Power: 14 |
Hi,everyone again
I Installed some software and the error now becomes “Received exception: Assertion failed in MeshPacket.cc, line 2550: this_mp && this_mp->numOwners” in .trn file: "ERROR: MeshPacket 12 does not exist." Anyone can offer some suggestions? |
November 27, 2011, 07:25 |
simon bob
Rep Power: 14 |
Today,i tried to install gambit in linuxmint12(virtualbox).
The same error occurred when i clicked the save button,the model is MODELING A MIXING ELBOW (2-D) from GAMBIT Tutorial Guide,It's a simple one,so i don't think the error come from calculation of overload. I guess some related packages are too new for gambit.But i don't know which package(Xorg? lesstif?). Can someone help me? |
March 19, 2013, 04:11 |
note
#4 | |
vlg
Rep Power: 17 |
http://forums.fedoraforum.org/archiv.../t-256522.html compile c code to memcpy preload library with gcc with option -m32 for lnx86. It does the trick. |
dbfree, error, gambit, linux |
[OpenFOAM] Change the number of digits for the data saved in csv files ParaFoam | mdmoura | ParaView | 0 | November 1, 2011 16:29 |
[OpenFOAM] Saved DATA doesnt have Patch Names | velan | ParaView | 0 | January 9, 2009 07:32 |
Getting Time Series data from saved unsteady data | Atul | FLUENT | 4 | November 26, 2008 05:12 |
information from saved data files:Unsteady flow | Atul | FLUENT | 5 | July 27, 2008 20:05 |
scripting gridgen: why a connector is not saved?? | Tim | Siemens | 2 | July 28, 2007 16:11 |
