-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [TurboGrid] Turbocharger Compressor Wheel Meshing (http://www.cfd-online.com/Forums/ansys-meshing/114953-turbocharger-compressor-wheel-meshing.html)
aymen_a22 March 20, 2013 11:27
This is my first post, I am carrying out an analysis on a turbocharger compressor wheel to compare it with the compressor map given for a specific compressor.
I have created a geometry of the compressor wheel using Blade Gen and have imported it into TurboGrid to create a mesh.
I am assuming constant mass flow rate and I am also assuming no pre-whirl.
I am unsure of a few things:
1: What turbulence model should I be using for the most accurate results?
2: How would I go about improving the mesh quality?
3: I know ambient temperature and pressure and would like to calculate outlet pressure, temperature and velocity. Is this possible?
4: I have not taken into account the diffuser as I do not know how to. How would I go about this as from what I understand, the pressure increase is a result of the diffuser (nozzle), the compressor wheel only pumps to increase the velocity.
5: How do I take into account the rotating compressor wheel as Turbogrid only imports one blade?
If anyone could help it would be greatly appreciated.
Kind regards.
