-   ANSYS Meshing & Geometry (https://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Import IGES file from CATIA to ICEM CFD 13.0 (https://www.cfd-online.com/Forums/ansys-meshing/115095-import-iges-file-catia-icem-cfd-13-0-a.html)
Prince@NTUA March 23, 2013 15:07
Hello All,
I have designed a very simple line sketch in CATIA v5, (it looks like a bullet - axis-symmetric) and I want to import it as IGES to ICEM - CFD (that;s the file format I have in mind). I want to proceed with a C-Mesh creation. I make the block and associate the edges of the block with the curves of the outer domain. When I have to arrange the mesh properties (max size) of Farfield , outflow and sketch, the mesh is not created. I have found out that it has to do with the IGES input geometry.
Is there any procedure that should I follow at the very beginning when I import the IGES file to ICEM CFD??
Thanks in advance.
Dimitris
jthiakz March 23, 2013 16:57
better save your CATIAV5 model into CATIA V4 **.model instead of IGES. then import the same CATIA V4 model in ICEM CFD.while importing check the option to keep the sketch points & curves with surfaces if u have any.
# After blocking
# chk block quality, then convert that into mesh.
Prince@NTUA March 23, 2013 17:22
thank you so much. It really worked !! :)
